Post by Fossilman on Jun 19, 2019 9:57:50 GMT -5
Aurora Borealis.....
Mahogany with gold sheen...
Post by Deleted on Jun 19, 2019 10:04:06 GMT -5
Video does do a better job of showing how the colors flash in and out of view. You're getting some nice cuts!
MommaGem
Member since April 2019
Post by MommaGem on Jun 19, 2019 10:32:42 GMT -5
Beautiful cuts! That obsidian is stunning. Shrek looks a bit intimidating
bsky4463
Member since September 2013
Post by bsky4463 on Jun 19, 2019 10:41:43 GMT -5
Sa-weet!
Post by miket on Jun 19, 2019 10:56:20 GMT -5
Gorgeous. I always have a problem cutting obsidian, can a dull blade cause this?
Post by Fossilman on Jun 19, 2019 11:52:17 GMT -5
Gorgeous. I always have a problem cutting obsidian, can a dull blade cause this? Obsidian actually dresses a blade up - that's why I got it often... There are a few tricks to bring the diamonds back out on a saw blade... Some use a file, some a ball pin hammer... Tap lightly on the face of the blade while manually rotation the blade..(Gentle taps)
Post by miket on Jun 19, 2019 12:00:38 GMT -5
Gorgeous. I always have a problem cutting obsidian, can a dull blade cause this? Obsidian actually dresses a blade up - that's why I got it often... There are a few tricks to bring the diamonds back out on a saw blade... Some use a file, some a ball pin hammer... Tap lightly on the face of the blade while manually rotation the blade..(Gentle taps) I have heard that before, I just get a lot of fractures trying to cut slabs. Thanks for the tips!
Post by Fossilman on Jun 19, 2019 15:30:37 GMT -5
Obsidian actually dresses a blade up - that's why I got it often... There are a few tricks to bring the diamonds back out on a saw blade... Some use a file, some a ball pin hammer... Tap lightly on the face of the blade while manually rotation the blade..(Gentle taps) I have heard that before, I just get a lot of fractures trying to cut slabs. Thanks for the tips! Do you have a rock saw or a Tile saw? Seems from 10" and up(Blades), Obsidian slabs great on rock saws...
Post by Rockindad on Jun 19, 2019 15:36:17 GMT -5
Nailed it, they look awesome. Do you make some experimental cuts to get the orientation just right or can you tell from the rocks exterior? Never cut Obsidian like this, my understanding is you need to get it just right.
Al
Post by miket on Jun 19, 2019 15:37:59 GMT -5
I have heard that before, I just get a lot of fractures trying to cut slabs. Thanks for the tips! Do you have a rock saw or a Tile saw? Seems from 10" and up(Blades), Obsidian slabs great on rock saws... Sadly just a tile saw with a teeny 7" blade- for now.
Post by hummingbirdstones on Jun 19, 2019 20:35:43 GMT -5
Beautiful cuts!
Post by Fossilman on Jun 19, 2019 21:45:02 GMT -5
Nailed it, they look awesome. Do you make some experimental cuts to get the orientation just right or can you tell from the rocks exterior? Never cut Obsidian like this, my understanding is you need to get it just right. Al[/quote Got lucky on this one, with a good teacher, showing me the ropes...
Post by Fossilman on Jun 19, 2019 21:46:09 GMT -5
Do you have a rock saw or a Tile saw? Seems from 10" and up(Blades), Obsidian slabs great on rock saws... Sadly just a tile saw with a teeny 7" blade- for now. Tile saws will blow Obsidian while cutting.. to bad!!
Post by TheRock on Jun 19, 2019 23:52:12 GMT -5
Nice Cuts!
