mapleann
Member since July 2019
Post by mapleann on Jul 25, 2019 7:11:03 GMT -5
Going to be getting a Lot O soon and I’m wondering about the pros and cons of using my small scrap, rough and slab scrap, as filler. Is it wise to totally use scrap with no ceramic or should you have a mix? Should you mostly use scrap that is about the same dimensions as the ceramic or is a larger size or a mix of size ok? Got any other advice on the topic? There must have been a lot of experimentation amongst you experienced with vibes.
Post by Fossilman on Jul 25, 2019 9:21:37 GMT -5
I use my scraps.. All sizes and shapes, works like a charm..
Post by rmf on Jul 25, 2019 9:24:17 GMT -5
I always use scraps because it is cheap. I had a customer that had me cut up "stones" for jewelry from broken porcelain dishware. The porcelain scraps I have used in the fine and polish cycle. They are soft compared to quartz family but they work.
