Rockshund
Member since July 2019
Post by Rockshund on Aug 5, 2019 10:19:15 GMT -5
My little 3-pound Thumbler AR-1 tumbler barrel leaks a little at the lid and recently the lid came off and spilled my batch on the floor. Does anyone know of a better design that will fit this machine?
Post by quartz on Aug 5, 2019 22:45:59 GMT -5
One thing I have found with these tumblers is the o-ring that holds the lid tight is sometimes too loose. I've found a 1/4" diameter o-ring that will just slip inside the empty barrel works well to seal the lid. In other words, the outside diameter of the o-ring is the same as the inside diameter of the barrel. O-rings normally available at industrial supply or good auto parts stores.
jasonshort
Member since June 2019
Post by jasonshort on Aug 14, 2019 17:14:23 GMT -5
I have the same tumbler. Really have to scrub in the groove with a toothbrush to get the lid to seal. Just broke the belt and used one of mr wifes rubber hair ties.. works like a champ...lol
madman
Member since June 2020
Post by madman on Jun 15, 2020 20:41:16 GMT -5
I simply put two on the outside groove.no leaks so far.😀
