Post by kellykellykelly on Aug 13, 2019 11:47:01 GMT -5
Post by fernwood on Aug 13, 2019 13:36:03 GMT -5
That is nice.
gemfeller
Member since June 2011
Member is Online
Post by gemfeller on Aug 13, 2019 14:32:41 GMT -5
kellykellykelly, are you sure it's an agate? Does it seem unusually heavy? Just judging from your images and your comment that it has a metallic sheen, I wonder if it might be a hematite nodule. It sure looks like one to me.
Post by MsAli on Aug 13, 2019 15:08:05 GMT -5
kellykellykelly , are you sure it's an agate? Does it seem unusually heavy? Just judging from your images and your comment that it has a metallic sheen, I wonder if it might be a hematite nodule. It sure looks like one to me. That was my thoughts
rockstock
Member since April 2019
Post by rockstock on Aug 13, 2019 18:47:29 GMT -5
Did it have the metallic sheen before using a steel brush? Did the brush cause your sheen perhaps?
stonemon
Member since January 2017
Post by stonemon on Aug 13, 2019 20:30:43 GMT -5
I am with rockstock... the wire brush can leave that sheen. It looks like agate to me and a good one at that. Just sayin'....
gemfeller
Member is Online
Post by gemfeller on Aug 13, 2019 21:37:52 GMT -5
I must have been reading fast and missed the "steel" part of brushing the stone. Yes, that could definitely cause a metallic sheen. I've had it happen to my stones.
Post by wigglinrocks on Aug 14, 2019 9:31:35 GMT -5
Did it have the metallic sheen before using a steel brush? Did the brush cause your sheen perhaps? Been there , done that .
Post by miket on Aug 14, 2019 9:35:51 GMT -5
Did it have the metallic sheen before using a steel brush? Did the brush cause your sheen perhaps? Been there , done that . I used a metal brush,too, when I first started. And yep, it left a sheen so I don't anymore.
Post by kellykellykelly on Aug 20, 2019 2:36:51 GMT -5
Yes I used a metal steel brush: Thanks Stonemon and Rockstock. I will re-wash it. I will not use a steel brush anymore. I will re-take photos of this and post again because I think with the metallic sheen it is hard to see the windows and small bands in other areas.
