Post by fernwood on Aug 14, 2019 5:20:50 GMT -5
Found in a bag labeled Apache Mine. Cast Iron. I could see where this would be helpful removing smaller rocks. If not a tool, what is it? Scrap metal? The side ridges are interesting. Thanks
Post by wigglinrocks on Aug 14, 2019 8:42:31 GMT -5
Looks like the second choice is correct , a piece of torch cut scrap metal .
Post by fernwood on Aug 14, 2019 8:49:54 GMT -5
I can use this myself for getting rocks out of hardened ground for sure.
Post by wigglinrocks on Aug 14, 2019 8:55:10 GMT -5
I can use this myself for getting rocks out of hardened ground for sure. A long heavy duty screwdriver works better . They have better handles .
Post by Fossilman on Aug 14, 2019 9:04:25 GMT -5
Yuppers, scrap torch cut metal... seen this everywhere in the oilfields...
Post by miket on Aug 14, 2019 9:05:09 GMT -5
I can use this myself for getting rocks out of hardened ground for sure. A long heavy duty screwdriver works better . They have better handles . I use screwdrivers also, the cheap ones from Walmart. Like a dollar each. That way when I set it down and lose it it's no big deal! 🙂
Post by wigglinrocks on Aug 14, 2019 9:23:51 GMT -5
Cheap is good , heavy duty cheap is even better . Especially when beating on them to get a prize rock out of frozen ground .
Post by greig on Aug 14, 2019 13:36:06 GMT -5
Looks like something leftover when patching a piece of heavy equipment. You sometimes see this sort of thing on Gold Rush or Yukon Gold when they fix a wash plant. Except maybe they don't toss the leftover iron into the tailings on those shows, but I can tell you from lots of time in mines that junk like this are everywhere. Awful thing to hit with your tires.
Post by fernwood on Aug 14, 2019 14:07:40 GMT -5
I think it is a cool piece of history. Who knows how old it is. Way back when, someone picked it up and felt it was worth saving. Knowing the exact mine it came from is a plus to me.
Post by Rockoonz on Aug 14, 2019 22:22:57 GMT -5
Did your bag also have vanadium ore in it?
Post by fernwood on Aug 16, 2019 6:44:08 GMT -5
Did your bag also have vanadium ore in it? Not unless it was included in other rocks. There were a couple pieces of what appears to be Chlorargyrite with some crystals and other materials.
