Post by stardiamond on Sept 12, 2019 17:21:51 GMT -5
Today was a cab fix day. I put 4 cabs on dops and a Howardite that had a minor fractured edge in my pocket and went to my outside cabbing area. I reached into my pocket and pulled out 4 cabs on dops and the Howardite was gone. The only place it should have been was by my feet. I looked for a short while and then worked on the other cabs. My work area could best be described as a pig sty. The floor is dirt and from working on it a couple inches of dust. I got a rake and swept the dirt into a pile and then sifted through it. No cab. I did find a Tahoma that I made a long time ago and thought I could put a better polish on it. It went flying off the polishing pad and took an interesting path. I also found a dop stick and uneven slab of Bruneau that I can probably make a cab with. This happens frequently. Sooner or later the Howardite will reappear.
Post by Fossilman on Sept 13, 2019 9:09:49 GMT -5
It will be in the most unusual spot too.....
Post by stardiamond on Sept 21, 2019 15:33:26 GMT -5
This pet wood disappeared a week ago from an outdoor coffee table that I used to select cabs to work on. It reappeared today on the same table. I spent some time looking for it.
julieooly
Post by julieooly on Sept 21, 2019 17:37:00 GMT -5
Blue pet wood?? What's it called its beautiful! You probably won't understand this but you may have wrackspurts.
Post by stardiamond on Sept 21, 2019 19:47:48 GMT -5
Maybe. This is what it looks like polished: [/
