Post by manofglass on Sept 13, 2019 9:55:11 GMT -5
just use PVC Primer and Glue to seal it 2" hole 5/8" cold rolled rod 5/8" Motor Shaft Arbor 5/8" bearings 6" pulley 5/8" bore 3 5/8" shaft collars Pieces of rubber to place under the bucket where the screws go to fill the gap 36 grit disk from jadecarver.com
Post by Deleted on Sept 13, 2019 10:03:06 GMT -5
That is awesome!
Post by Drummond Island Rocks on Sept 13, 2019 13:08:59 GMT -5
Should work just fine. The top picture looks like the splash shield is lower then the disc but the bottom picture looks like the splash shield is higher? Could be an optical illusion from the angle the pictures were taken. Engineering question though. Is there any difference between adding the pulley between the two pillow block bearings VS putting the pulley at the bottom of the shaft below the bottom bearing? Just wondering if that would make any difference in vibration transfer. I have seen it done both ways. jamesp has a bunch of home built stuff maybe he can chime in too. Chuck
Post by Jugglerguy on Sept 13, 2019 14:02:02 GMT -5
That looks great, Walt! Nice work.
Post by manofglass on Sept 13, 2019 17:21:57 GMT -5
Should work just fine. The top picture looks like the splash shield is lower then the disc but the bottom picture looks like the splash shield is higher? Could be an optical illusion from the angle the pictures were taken. Engineering question though. Is there any difference between adding the pulley between the two pillow block bearings VS putting the pulley at the bottom of the shaft below the bottom bearing? Just wondering if that would make any difference in vibration transfer. I have seen it done both ways. jamesp has a bunch of home built stuff maybe he can chime in too. Chuck It was higher in the first photo But when I changed the arbor I removed that Part it was a Aluminum back plate Didn’t fit the new arbor
Post by HankRocks on Sept 13, 2019 17:34:10 GMT -5
Good job!!! love those home-made projects.
NDK
Post by NDK on Sept 13, 2019 23:46:24 GMT -5
Well done Walt. You should get many years of service out of it!
Post by fernwood on Sept 14, 2019 3:12:41 GMT -5
Nice build. Like the photos showing aspects of the unit.
Post by miket on Sept 14, 2019 8:54:08 GMT -5
Great job, my friend. I'm sure it will do a fantastic job!
Post by MsAli on Sept 14, 2019 21:39:03 GMT -5
Great job Walt!
El JeffA
Member since February 2016
Post by El JeffA on Sept 14, 2019 21:47:41 GMT -5
Looks good Walt !
Post by manofglass on Oct 4, 2019 13:26:50 GMT -5
Finished
Post by miket on Oct 4, 2019 16:20:38 GMT -5
Love the hearts, great work!
bluechert
Member since March 2022
Post by bluechert on Apr 17, 2022 15:27:36 GMT -5
Sorry I know this is an older thread, but- I had a couple questions for the builder. What are you running for a motor on this? I'd be curious to know the RPMs and H.P. I'm going to be building one soon, but money is very tight right now so I'm trying to scavenge/reuse as many components as possible. I've seen video of smaller cheap tile saws being modified into flat laps with (apparent)success.
Post by hummingbirdstones on Apr 17, 2022 15:49:42 GMT -5
Sorry I know this is an older thread, but- I had a couple questions for the builder. What are you running for a motor on this? I'd be curious to know the RPMs and H.P. I'm going to be building one soon, but money is very tight right now so I'm trying to scavenge/reuse as many components as possible. I've seen video of smaller cheap tile saws being modified into flat laps with (apparent)success. I'm tagging Walt manofglass for you.
Post by Tommy on Aug 22, 2022 10:22:07 GMT -5
Bumping this one up for inclusion on the DIY page. I hate to think how many good builds like this I miss when I'm not paying attention
