jasonshort
Member since June 2019
Post by jasonshort on Sept 13, 2019 19:50:56 GMT -5
jasonshort
Post by jasonshort on Sept 13, 2019 23:04:42 GMT -5
Could it be aventurine or jadeite?
Post by Fossilman on Sept 14, 2019 8:31:48 GMT -5
Or green Quartz...
jasonshort
Post by jasonshort on Sept 14, 2019 11:45:34 GMT -5
I think I lest out that the rock is from montana
Post by Deleted on Sept 14, 2019 13:19:51 GMT -5
Could be amazonite. Mindat only shows one location in Montana for that (west of Butte), not that there might be others. If you can do a scratch test to give an approximate hardness, that might help narrow down what it may be. The Mohs hardness for amazonite is 6.
jasonshort
Post by jasonshort on Sept 14, 2019 15:44:05 GMT -5
I scrached it with a kitchen knife and got a while line. Not sure how to tell if it is a 6
hh5
Member since January 2012
Post by hh5 on Sept 16, 2019 18:52:40 GMT -5
I recently saw some calcite that looked similar. Put a drop of vinegar on a spot of the rock and see if it bubbles. I had to use a magnifying glass to see the bubbles.
Post by rmf on Sept 16, 2019 21:41:45 GMT -5
If you scratched it with a knife then it is not quartz, jade, quartzite or amazonite. I would say serpentine.
NRG
Member since February 2018
Post by NRG on Sept 20, 2019 14:35:44 GMT -5
Looks like a mudstone to me.
Post by Deleted on Sept 20, 2019 20:19:58 GMT -5
Depends on the hardness of the knife (range from 5-6.5) the harder of which can scratch amazonite (Mohs 6). The suggestion by hh5 to test with vinegar see if it bubbles (limestones, calcite, apatite, etc.) is a good one. If you don't know the hardness of your knife, try using known rocks from the list at the that link to narrow things down.
thedude
Member since November 2019
Post by thedude on Nov 26, 2019 11:20:00 GMT -5
Fuchsite.
