einholt
Member since May 2019
Post by einholt on Sept 29, 2019 20:09:36 GMT -5
I actually tripped over this walking through my back yard. Just West of St Louis. It's a little paler, almost beige, in person. It doesn't scratch with a blade, looks a bit like a worn-down version of a botryoidal quartz I picked up a while back.
Post by MsAli on Sept 30, 2019 20:52:32 GMT -5
That is a neat little find
Post by rockjunquie on Oct 1, 2019 6:36:18 GMT -5
Very cool! Do you cab or tumble? I can see a very awesome cab made of that with the tops polished. (depending on the size)
Post by TheRock on Oct 1, 2019 9:13:40 GMT -5
Very nice piece. what is size of it length, width, height.
einholt
Post by einholt on Oct 1, 2019 19:49:56 GMT -5
About 5 inches by 3, and an inch thick. I mostly tumble, the closest I've come to cabbing is a handful of guitar picks.
rads
Making clay each day!
Member since April 2018
Post by rads on Oct 2, 2019 8:49:27 GMT -5
It is a Chalcedony rose.
einholt
Post by einholt on Oct 2, 2019 19:46:21 GMT -5
How would one go about polishing this? Would a dremel or hand polishing of some sort be better than trying to use my sanding wheel?
rads
Post by rads on Oct 3, 2019 8:08:00 GMT -5
It's as hard as an agate, it can be cut and worked on wheels. It's very hard to get a thick enough cut to work with, due to the narrowness of the rose. I have managed a few 18mm x 13mm rings out of roses about the size of yours. Tend to work the areas of the bubbles that will center in the cabochon. FYI; Tumbled, they look like a chunk of shiny snot, according to my wife.
rjbud1
Member since November 2015
Post by rjbud1 on Oct 5, 2019 0:07:36 GMT -5
Very cool! Do you cab or tumble? I can see a very awesome cab made of that with the tops polished. (depending on the size) I agree. This would make a very interesting cab.
einholt
Post by einholt on Oct 12, 2019 10:32:23 GMT -5
I found this piece of quartz in the yard, started it in the tumbler and realized I've never seen orange stripes in quartz before. Anyone seen anything like it?
Post by rockjunquie on Oct 12, 2019 10:35:26 GMT -5
Carnelian is quartz. Maybe it's carnelian.
Post by rmf on Oct 22, 2019 4:10:22 GMT -5
If you were west of St Louis then it is Missouri Lace Agate.
