Post by toiv0 on Oct 21, 2019 12:12:05 GMT -5
Got this on one of the last deals I made. About the size of a burnished. Triangle blade hollow ground and pretty sharp. I have no idea.
agatemaggot
Member since August 2006
Post by agatemaggot on Oct 21, 2019 12:35:12 GMT -5
That is not a Black smith tool, it is a de-burring tool used on a Lathe to de-burr the inside edges of a part being turned with a hollow center. It is held at an angle and one of the corners makes contact with the burr on the sharp edge and with a small amount of pressure the burr is sliced off the edge and it can be used to create small champers on the edges also !
Post by Pat on Oct 21, 2019 13:19:45 GMT -5
Could it be used to debur castings? That white container in the box could be casting flux.
Post by pauls on Oct 21, 2019 15:19:32 GMT -5
As agatemaggot said, an engineering tool, handy for cleaning up burrs on holes, drill holes as well as lathe bored holes. It could be used by hand for rough cleaning up the inside of rings, it is good for holes. You will find it is quite difficult to use for outside cleaning up though.
Post by toiv0 on Oct 21, 2019 15:20:18 GMT -5
Could it be used to debur castings? That white container in the box could be casting flux. White container hols a gold melting crucible.
agatemaggot
Post by agatemaggot on Oct 21, 2019 21:07:55 GMT -5
White container is probably Silver Solder Flux, the tool is used for de-burring on a part that is turning, on a stationary part it would be almost impossible at best. Used one for 55 years, trust me ! There are de-burring tools made for use on stationary work but they have a fairly good size handle and a removable / replaceable blade that swivels. The swivel blade type works very well on all types of machinable metal and is great for de-burring plastics. These store bought triangle tools are a little pricey and after I had several ( BORROWED ) I started making my own out of old broken Triangle files I picked out of the scrap tub at work. I just ground the file to a point like the store bought and then hollow ground each side, files were harder than store bought and stayed sharp longer !
Post by Deleted on Oct 22, 2019 13:20:00 GMT -5
Fluted reamer, used as already suggested
Post by toiv0 on Oct 22, 2019 20:09:44 GMT -5
It looks too dangerous to use without drawing blood. Wonder what the old timer used it for? was in a box labeled bench tools. Thanks for all the replies.
whyofquartz
So, Africa is smaller than I expected...
Member since December 2019
Post by whyofquartz on Dec 5, 2019 17:58:08 GMT -5
It is possible this is not smithing tool at all but an old-school bowlers tool for cleaning/reaming bowling balls. It looks larger than any de-burring tool I have seen.
