Post by miket on Dec 5, 2019 23:49:58 GMT -5
Started working this Fairburn tonight and I really want to cab it... But here's the back and it's making me wonder if I should tumble it instead... Pretty sure I'll just cab it.
Post by RocksInNJ on Dec 6, 2019 0:14:35 GMT -5
The force is with you!,!
EricD
High in the Mountains
Member since November 2019
Post by EricD on Dec 6, 2019 0:20:20 GMT -5
Cab it
Post by Pat on Dec 6, 2019 0:32:45 GMT -5
You can cab it as a two-sided cab.
EricD
Post by EricD on Dec 6, 2019 0:34:41 GMT -5
It already has an upper curve and a lower point
Post by fernwood on Dec 6, 2019 3:38:54 GMT -5
It would be a perfect 2 sided cab.
Post by hummingbirdstones on Dec 6, 2019 8:21:57 GMT -5
Cab it. It's early and I may not be awake enough yet, but I don't see anything overly attractive about the back side.
Post by rockjunquie on Dec 6, 2019 8:24:53 GMT -5
Cab it. I'm with Robin- the back ain't special- the front is.
Post by miket on Dec 6, 2019 10:38:11 GMT -5
Cab it. It's early and I may not be awake enough yet, but I don't see anything overly attractive about the back side. I think I am going to. This is one that my son cut and it's really thick. The patterns on the backside are revealing themselves more the more I grind on it to get it flat and a little bit thinner. I'm grinding it on the bottom to lessen the amount of grinding I need to do on the front to shape it so that I don't lose much of the pattern that it has- and to flatten it, of course. I didn't get much time to work on it last night (High School basketball season), but I should today at lunch. Thanks Robin.
Post by miket on Dec 6, 2019 10:38:58 GMT -5
Cab it. I'm with Robin- the back ain't special- the front is. Yep, it's getting cabbed. Wish me luck!
Post by miket on Dec 10, 2019 15:16:59 GMT -5
Welp, here's what I ended up with! Thanks for looking!
oldschoolrocker
Post by oldschoolrocker on Dec 10, 2019 15:45:10 GMT -5
Awesome job!
Post by miket on Dec 10, 2019 15:58:27 GMT -5
Thanks, it's in the rotary now. I'm happy that I didn't lose much of the patterns, and these usually take a good polish.
Post by TheRock on Dec 12, 2019 4:15:01 GMT -5
Looks great to me you did a nice job on it!
