Post by fernwood on Dec 7, 2019 6:48:43 GMT -5
Someone on the RTH FB page is using crushed grinder wheels for stage 1 tumbling grit. The wheels were worn and no longer usable for intended purpose. It is working great. Has anyone here done that before? Any thoughts on doing this?
oldschoolrocker
Post by oldschoolrocker on Dec 7, 2019 7:18:39 GMT -5
I'm pretty sure Jamesp uses broken up sic wheels as coarse stage grit. I'd tag him but not sure how.
Post by Fossilman on Dec 7, 2019 10:00:16 GMT -5
I'm pretty sure Jamesp uses broken up six wheels as coarse stage grit. I'd tag him but not sure how. Yuppers, sounds like James....
Post by knave on Dec 7, 2019 11:05:34 GMT -5
jamespI believe he also uses bulk ungraded SIC. Subscribing...
Post by jamesp on Dec 7, 2019 13:06:35 GMT -5
Who would do such a thing ? They were bought yes used and cheap. New are costly. Great 60 grit time release coarse grind abrasive method. ****Use tough tumbler barrels. "If it wears barrels fast it will wear rocks fast" www.flickr.com/photos/67205364@N06/sets/72157649671884531chunks reduced in size on sorta soft Rhyolite after the first 2 weeks but some slurry was poured out and water added to thin over the 2 week run. Suggest HDPE barrel
