Post by stardiamond on Feb 14, 2020 19:25:56 GMT -5
I found some more stuff to work on. The Horse Canyon fractured cutting the best scene and I ended up with one preform. The Laguna needed to be modified into a freeform Rhodo, Laguna, Luna, Horse Canyon, Sagenite. The Luna are about 10mm thick. I'll make a high dome on the smaller one and split the larger one and make a low dome/flat top to preserve the eyes. I'll split it later since my trim saw is not being friendly (I hate fracturing good material when every thing looks solid).
Post by stardiamond on Feb 15, 2020 13:12:58 GMT -5
I split the Luna this morning. I lay the slab face down and with templates under it, I find the place I want to cut and rotate the slab against a pencil flat on the table around it. I rotate the trim saw blade around the pencil line and when all the way around, push the blade through. I don't trust my skill just pushing through. I ended up with a small nub that I ground off. The preform is now 5mm thick and the eye goes through to the back, so I can put a low dome on the cab.
Post by RocksInNJ on Feb 15, 2020 22:22:54 GMT -5
Love that one under the quarter.
Post by Fossilman on Feb 16, 2020 10:05:56 GMT -5
Nice preforms!
hummingbirdstones2
Vince A., 1958-2023
Member since August 2018
Post by hummingbirdstones2 on Feb 16, 2020 10:59:34 GMT -5
You do have a great rough stash... .
