dirtsifter
Co to za kamyczek?
Member since September 2022
Post by dirtsifter on Sept 21, 2022 0:14:57 GMT -5
A load of self collected rocks from Lake Ontario and local roadsides going into a just received QT12
dirtsifter
Co to za kamyczek?
Test 2
Sept 21, 2022 0:20:40 GMT -5
Post by dirtsifter on Sept 21, 2022 0:20:40 GMT -5
OK then, can one crop the size of the photo and change orientation when uploading from the photo gallery on my phone?
Post by rockjunquie on Sept 21, 2022 5:58:21 GMT -5
OK then, can one crop the size of the photo and change orientation when uploading from the photo gallery on my phone? Tommy can best answer that question. I have never tried to edit with Cloudinary.
dirtsifter
Co to za kamyczek?
Post by dirtsifter on Sept 21, 2022 6:46:17 GMT -5
So I was able to look at a few posts. Learned to use the bcc code and change the size, it's a little awkward but I figured it out. Went back to cloudinary and decreased the transformation size. I had it set to 700 width.
But I can't figure out how to change the orientation size.
Well maybe tonight after a good days sleep
Post by Tommy on Sept 21, 2022 8:50:26 GMT -5
dirtsifter welcome to the forum and nice job muddling through the Cloudinary setup. I'm not sure if I fully understand what you wish to accomplish but there is a way to have images automatically rotated using incoming transformation. I've never used it or even played around with it much because the setting will rotate everything you upload even if it didn't need rotating.
electrocutus
Member since October 2020
Test 2
Sept 21, 2022 10:34:53 GMT -5
Post by electrocutus on Sept 21, 2022 10:34:53 GMT -5
dirtsifter are you on the US or Canadian side of the lake? I'm in Toronto :-)
dirtsifter
Co to za kamyczek?
Post by dirtsifter on Sept 21, 2022 20:22:20 GMT -5
US, Not far from Pulaski, NY.
dirtsifter
Co to za kamyczek?
Test 2
Sept 21, 2022 20:24:08 GMT -5
Post by dirtsifter on Sept 21, 2022 20:24:08 GMT -5
dirtsifter welcome to the forum and nice job muddling through the Cloudinary setup. I'm not sure if I fully understand what you wish to accomplish but there is a way to have images automatically rotated using incoming transformation. I've never used it or even played around with it much because the setting will rotate everything you upload even if it didn't need rotating. Thank you, sir. I will have a look at that.
dirtsifter
Co to za kamyczek?
Test 2
Sept 22, 2022 5:18:30 GMT -5
via mobile
Post by dirtsifter on Sept 22, 2022 5:18:30 GMT -5
dirtsifter
Co to za kamyczek?
Post by dirtsifter on Sept 22, 2022 5:21:08 GMT -5
Before I started muddling around, I didn't know there was a "desktop" option on a smart phone. I feel so old sometimes.
