Post by MsAli on Mar 9, 2023 13:47:38 GMT -5
@msali. I rarely use it, but it was helpful when I did. I mainly use the mini-butane Blazer, or the bigger crème-brûlée torch. I need to replace my butane and have always been interested in the ORCA. I found one that is a decent price, but not sure if it's worth getting
Post by Pat on Mar 9, 2023 13:51:33 GMT -5
If you need something bigger/hotter, Orca is one answer. Glad I have it. Home Depot sells smaller propane tanks. I like those as well.
Post by MsAli on Mar 9, 2023 15:22:22 GMT -5
Pat What would be something you'd use it for vs. just using the butane?
Post by Pat on Mar 9, 2023 15:25:50 GMT -5
I’d need propane for bigger items like cuff bracelets, or softening pieces to put through the rolling mill.
Post by MsAli on Mar 9, 2023 16:01:56 GMT -5
I’d need propane for bigger items like cuff bracelets, or softening pieces to put through the rolling mill. Thank you! That helps me a lot 😊
Post by hummingbirdstones on Mar 9, 2023 17:37:51 GMT -5
I’d need propane for bigger items like cuff bracelets, or softening pieces to put through the rolling mill. Thank you! That helps me a lot 😊 Ali, I have an Orca too. It works fine. Also use the small propane tanks. I usually buy mine at Wally's World.
Post by MsAli on Mar 9, 2023 17:45:26 GMT -5
I love the idea of using the small propane
Post by Starguy on Mar 9, 2023 21:57:58 GMT -5
Propane is ok but oxyacetylene is much hotter. I’ve had some pretty big fireballs from loose connections on oxyacetylene torches. The propane forge gets metal orange hot easily but if I need something really hot, break out the oa torch.
Post by MsAli on Mar 10, 2023 6:57:18 GMT -5
Propane is ok but oxyacetylene is much hotter. I’ve had some pretty big fireballs from loose connections on oxyacetylene torches. The propane forge gets metal orange hot easily but if I need something really hot, break out the oa torch. I can't imagine I'd need OA for anything I do
Tracie
Member since September 2022
Post by Tracie on Mar 12, 2023 23:35:52 GMT -5
I use an orca torch, I have never had any problems, I have had mine for a year or two and the hose has been just fine, I have had to clean the torch tips a few times. That’s not the first time I have heard that, I am sure at some point there was a bad batch or something. I used a small butane torch until it wasn’t enough to do everything I wanted to do. The orca can easily heat up a heavier gauge cuff bracelet.
