Post by liveoak on Nov 16, 2022 7:47:23 GMT -5
I'm collaborating with my husband to make a cell phone stand for possible Christmas presents.
They will be made out of aluminum, anodized & colored with a stone set in them.
The stand portion is a notch - so I'm trying to figure out how wide the notch has to be to fit over the majority of cell phones.
Mine, on the edge, with the case I have on, it is approx. 5/8" .
How about yours ?
Appreciate all & any input.
Thank you,
Patty
electrocutus
Member since October 2020
Post by electrocutus on Nov 16, 2022 9:57:25 GMT -5
I was trying to vote twice (like in all good elections :-) ) because I checked both my phone and my wife's. mine is 1/2" and my wife is 5/8".
Post by Rockoonz on Nov 16, 2022 10:32:35 GMT -5
Personal phone is .53" Work phone is .51" When I open the calipers to .63" (5/8 plus 5 thousanths") it seems to me to be a totally acceptable size, you could probably add about .100"to .125" radius to the front of the notch and it would mostly sort out any looseness. I would radius the back as well but only about .060 or use a 1/8" drill to locate it.
Post by liveoak on Nov 16, 2022 11:08:24 GMT -5
Noted Lee Rockoonz, I will pass that info onto Tom. Thank you, Patty
Post by jasoninsd on Nov 16, 2022 21:19:27 GMT -5
87 views and only 7 votes so far! Sheesh!
Mine is 1/2" but has small little "nubs" as protectors on the backside...so maybe an additional couple millimeters...
Post by rockjunquie on Nov 16, 2022 22:06:16 GMT -5
I voted for 1/2" but it's actually just a hair smaller. I have a Galaxy S20 FE with an Otterbox case (thin).
khara
Member since September 2022
Post by khara on Nov 16, 2022 22:13:03 GMT -5
87 views and only 7 votes so far! Sheesh! Mine is 1/2" but has small little "nubs" as protectors on the backside...so maybe an additional couple millimeters... Iām trapped under the cat and donāt have a tape measure on me.
Post by Pat on Nov 16, 2022 22:14:32 GMT -5
If you made the slot to fit the biggest size, wouldnāt I it fit all the sizes?
I have iPad holder made of wood. I like it. Metal with a stone sounds very very nice!
khara
Post by khara on Nov 16, 2022 22:53:10 GMT -5
liveoak I voted for 1/2ā but mine is actually 7/16ā
Post by fernwood on Nov 17, 2022 3:44:24 GMT -5
Mine is 5/8" with the case. It is an I Phone 12 Mini. Overall size is pretty small compared to most cell phones.
Post by liveoak on Nov 17, 2022 7:14:09 GMT -5
Thanks for everyone's input ( and jasoninsd for the nudge ) , That's the exact idea Pat, to make it to fit the largest size, so I needed to know what that largest size is. It sounds like a slot slightly larger than 5/8" would accommodate most.
We're still in the design stage - we want a design that actually works.
Thanks for the help,
Patty
Post by Pat on Nov 17, 2022 10:56:14 GMT -5
Hmmm, good point! Missed that!
Post by Tommy on Nov 18, 2022 11:07:07 GMT -5
My Samsung S20U with a hard case is 1/2" but the case was originally a tripod stand that broke off but it still has about another 1/8th raised surface where the stand used to be.
Post by liveoak on Nov 18, 2022 11:25:09 GMT -5
Sounds like 5/8" Tommy , thanks for the vote.
Patty
Post by realrockhound on Nov 19, 2022 1:17:17 GMT -5
1/4 inch
Post by liveoak on Nov 19, 2022 7:26:28 GMT -5
I'm going to guess you don't have an added case ?
Patty
Post by realrockhound on Nov 19, 2022 12:34:14 GMT -5
Patty
I do. Iām using an iPhone with a standard hard cover.
quartzilla
Member since April 2020
Post by quartzilla on Nov 20, 2022 17:31:33 GMT -5
I have just a hair over 5/8ā with a otter box case.
Post by Pat on Nov 21, 2022 14:32:08 GMT -5
My iPhone plus protective cover is .45ā.
Post by liveoak on Nov 21, 2022 14:59:30 GMT -5
Thanks Pat. Tom started on the machining yesterday. With any luck the design will work with the variety of sizes we've come up with here. I appreciate everyone's input. Will post a photo when they are done. Patty
