ericabelle
Instagram acct: @erica_shoots_everything
Member since April 2021
Post by ericabelle on Dec 26, 2022 14:17:29 GMT -5
Post by fernwood on Dec 26, 2022 15:29:52 GMT -5
Could the outer layer be limonite?
khara
Member since September 2022
Post by khara on Dec 26, 2022 17:12:47 GMT -5
They kind of look like they might be Carnelian to me, especially if you are still seeing red after being able to scrape some crust off. I don’t know, tough choice, they do look cool as is. I dug some carnelian years ago and cleaned it in muriatic acid. There was some druzy that got nice and clear and then I also ground and polished some faces to make a nice little display piece. The shape of that first one looks like there might be some banding going on along with the cool botroidals.
ericabelle
Post by ericabelle on Dec 26, 2022 18:12:30 GMT -5
Could the outer layer be limonite? Judging by photos of limonite online, I think it could be. Whatever it is, it's pretty thick.
ericabelle
Post by ericabelle on Dec 26, 2022 18:17:32 GMT -5
They kind of look like they might be Carnelian to me, especially if you are still seeing red after being able to scrape some crust off. I don’t know, tough choice, they do look cool as is. I dug some carnelian years ago and cleaned it in muriatic acid. There was some druzy that got nice and clear and then I also ground and polished some faces to make a nice little display piece. The shape of that first one looks like there might be some banding going on along with the cool botroidals. Carnelian- yes, could be, especially the first one. It also has the look of agate on the bottom. The second one definitely has some metallic substance in it, but I'm not sure what else. I'm probably just going to have to put them in iron out and see how it turns out!
Post by fernwood on Dec 27, 2022 3:30:21 GMT -5
Post by Peruano on Dec 27, 2022 7:22:50 GMT -5
You may end up with black, black, black.
Post by rmf on Dec 28, 2022 8:33:26 GMT -5
ericabelle I would not use limeout. You have a Limonite psuedomorph after Pyrite. Is this two different stones? The last two images have what looks like Pyrite crystals. These then would be altered to the limonite. The top images look like botryoidal pyrite again converted to limonite. clean with brush and mild abrasive or sandblast with baking soda.
ericabelle
Post by ericabelle on Dec 29, 2022 10:28:25 GMT -5
ericabelle I would not use limeout. You have a Limonite psuedomorph after Pyrite. Is this two different stones? The last two images have what looks like Pyrite crystals. These then would be altered to the limonite. The top images look like botryoidal pyrite again converted to limonite. clean with brush and mild abrasive or sandblast with baking soda. No, I wasn't thinking of using limeout. I think the second rock definitely has some pyrite, so I've been researching the different ways of cleaning pyrite. Apparently, a lot of people soak in Iron Out or Simple Green. But, I'll try brushing it first. What would you consider a mild abrasive? Borax maybe? I also have some Barkeeper's Friend, but that may not be too mild.
Post by rmf on Jan 8, 2023 21:17:44 GMT -5
ericabelle the best way to clean pyrite crystals is with a sand blaster and baking soda. If just a piece or two try baking soda with tooth brush.
