hypodactylus
Member since July 2021
Post by hypodactylus on Jun 9, 2023 20:42:47 GMT -5
I am worried that all the stones have crescent moon bruises. I can spot them easily in the translucent portions of the wood, but I assume they're probably still there in the opaque portions, just less noticeable. I'm not sure how detectable they may be in the end if they are there, so I'm re-tumbling them all.
Yeah, the bruises look like rock-on-rock impact points from the tumbling process.
I have been frustrated by these in my QT12 and have been obsessively messing with my process to eliminate them. They seem to mostly plague hard transparent rocks, more so as they get larger.
To combat this, I have been adding a lot more small (ceramic media sized) rocks to my large barrel tumbles. I have also been putting the more susceptible rocks in smaller barrels.
The jury is still out on how effective my efforts have been; it can often be difficult to tell until they are at least close to finished.
elpam
Member since June 2022
Post by elpam on Jun 12, 2023 21:32:54 GMT -5
Chiming in...
Down to the last stretch...
Rinsed in borax for 24 hrs and used the waterpic to detail rinse the rocks. I'm pushing on to 500 grit.
Again, rocks are not perfect but look pretty when wet.
After looking at hefty's last pics. Mine have the same crescent fractures, some are rough in spots and a few have larger cracks/pits. I've only tumbled mine in a rotary tumbler...with small ceramics from day one. My rocks are getting pretty small...compared to starting size.
Up until now..I've just followed the steps I knew. Now, I'm a bit nervous about the polish. Aluminum oxide? Tin oxide? I'm sure there is others out there....what's best?
elpam
Post by elpam on Jun 13, 2023 9:41:29 GMT -5
Do we know how many contestants there are?
cthomas
Member since April 2023
Post by cthomas on Jun 17, 2023 15:02:59 GMT -5
I still haven’t set up my cloudinary account. I did just post some photos over on Reddit though. I’ll try to get them here shortly.
Most of mine are now finished and man they are shiny! Unfortunately a lot of them chipped in stage 4 and so now I’m going to have to choose the best of the worst to submit. I still have two large pieces that are still in stage 1 but I doubt they will be done in time or be crack free.
Good Luck!
elpam
Post by elpam on Jun 19, 2023 20:24:40 GMT -5
Those are shiney! Nicely done...
Post by Son Of Beach on Jun 20, 2023 19:31:37 GMT -5
Reminds me of one of those amateur chefs on the cooking contest shows who decides to mix it up late in the clock and try something new and different.
What will the judges have to say about that!
Post by jasoninsd on Jun 23, 2023 19:55:32 GMT -5
@hefty - I wish I had some help for you, but I don't tumble enough. I will recommend you start a new thread with your above post. Sometimes people don't always jump into a long-running thread. If you title your thread with something like..."Need help with moon shaped bruise and undercutting" (or something like that), I bet you'll get more responses.
I've never used Karo...but I have used sugar in a couple batches.
geoff59
Member since October 2022
Post by geoff59 on Jun 30, 2023 17:44:32 GMT -5
I associate foam in slurry with protein content of any sort. The foam you see in streams and rivers is basically proteins from partially broken down organics. So the karosyrup, being a vegetable based organic, will also have certain protein/compounds within it, especially if it gets watered down and agitated (same idea as a stream does to decaying leaves for example) A lot of my drums that I open, they also have foam just like in your photo. You should keep extensive notes on everything you tumble, especially anything that is new. That’s one of the things you’re doing here in this thread, btw, focused on this contest rock. The ‘new” could be new rough or something new within the “recipe” you use. Or even the media you use to surround the rock you’re tumbling. I am far from anything like an expert with tumbling rocks or tumbling petrified wood, but I’ve found that often times, what I use as “pellets” to cushion the rock seems to have a significant effect on the quality of the end result. Why this is so, I am not sure, I only know that sometimes, ceramic pellets don’t seem to be a good choice, while maybe pea gravel might result in a much higher quality tumble. And I know that petrified wood has a lot of variation within rock from the same location, even within the same petrified log or branch. There is nothing consistent with the rock itself, which is why it’s a great choice to use for a contest. It’s all beautiful rock, and it’s also really tough to produce polished rock without flaws in it. No matter where it comes from. Does anyone here not agree to this? I keep a pretty extensive journal/diary of my tumbles as I go along. If nothing else, the writing/typing really helps me learn and store info in to my damaged brain cells, which believe me need all the help they can get!
elpam
Post by elpam on Jul 3, 2023 19:29:53 GMT -5
Finally....on the last stage...polish.
Then a borax rinse....I hope they turn out shiney!
Good luck everyone!!
Post by velodromed on Jul 4, 2023 11:50:33 GMT -5
I’ve been enjoying this post @hefty ! Enough so that my wife and I just decided to try the contest out next year, if possible. Much appreciated and good luck!
elpam
Post by elpam on Jul 4, 2023 22:22:03 GMT -5
elpam you better show pictures!
elpam
Post by elpam on Jul 4, 2023 22:22:29 GMT -5
elpam
Post by elpam on Jul 4, 2023 22:23:15 GMT -5
Yes...if I can figure it out...lol
elpam
Post by elpam on Jul 17, 2023 22:43:14 GMT -5
Hmmm...I tried the cloudinary upload and it says upload preset failed. Any ideas?
elpam
Post by elpam on Jul 17, 2023 22:44:33 GMT -5
And I don't even know what a shout box is....so sorry for whatever I did...
elpam
Post by elpam on Jul 24, 2023 18:23:32 GMT -5
elpam
Post by elpam on Jul 24, 2023 18:25:56 GMT -5
do you see a picture?...
Edit: I think it worked.... good grief ....desktop is the way to go!
Sent my entry in today...
geoff59
Post by geoff59 on Jul 24, 2023 19:30:43 GMT -5
do you see a picture?... Edit: I think it worked.... good grief ....desktop is the way to go! Sent my entry in today... Looking good from here! Nice job! I don’t expect to be anywhere near the top 3, mine were sent in a few weeks ago. One thing I will add: it is for sure some of the most beautiful petrified wood I have ever tumbled. I go in to a bit of a fugue-state every time I look at the rocks that stayed home with me. I think, I would make a guess, it’s from Saddle Mountain. But I don’t know for sure.
pebblesky
Placed another order in rockshed. Happy 2024 everyone!
Member since September 2022
Post by pebblesky on Jul 24, 2023 22:03:59 GMT -5
They are beautiful and unique!
Post by Son Of Beach on Jul 25, 2023 20:34:51 GMT -5
Thats a cool little pattern, like when water or mud dries and shows what used to be.
You've got some nice looking rocks. Are some of these destined for entry?
