chelli
dreaming of rocks
Member since February 2023
Post by chelli on Feb 2, 2023 9:47:06 GMT -5
Hi, I'm new. I'm from the Philippines. I've always been fascinated by rocks. I got my NatGeo hobby tumbler today and saw how little grit was in the box. I know you're supposed to run Stage 1 a couple of times so I put off starting until I get more grit.
Now my problem is that I can only find silicon carbide #46 and aluminum oxide #60. Which of these should I get?
Post by Starguy on Feb 2, 2023 10:01:35 GMT -5
Hi chelli. Welcome to the forum. Silicon carbide grit will work the best for stage 1.
Post by Drummond Island Rocks on Feb 2, 2023 11:13:41 GMT -5
If those are my only two choices I pick the 46 S/C for sure. A/O is not good at removing rough spots in stage one.
vance71975
Member since September 2022
Post by vance71975 on Feb 2, 2023 17:11:32 GMT -5
As they said above, 46 Silcone carbide for stage one between those choices. Once you get it smooth with no cracks then you switch to Aluminum Oxide.
chelli
dreaming of rocks
Post by chelli on Feb 2, 2023 18:11:28 GMT -5
Thank you for the replies. Off to buy the SiC today!
dirtsifter
Co to za kamyczek?
Post by dirtsifter on Feb 3, 2023 2:56:01 GMT -5
Someone correct me if I'm wrong but 46 silicon carbide if left to roll in stage 1 for a long period of time would break down finer and finer even past stage 2 (220) and stage 3 (500), no?
Post by vegasjames on Feb 3, 2023 3:19:20 GMT -5
Welcome
vance71975
Post by vance71975 on Feb 3, 2023 3:28:32 GMT -5
Someone correct me if I'm wrong but 46 silicon carbide if left to roll in stage 1 for a long period of time would break down finer and finer even past stage 2 (220) and stage 3 (500), no? It should yes, in theory at least.
