rocknewb101
Member since October 2022
Post by rocknewb101 on Mar 12, 2023 7:41:17 GMT -5
Well, it's a sad day in my house...Lot-o motor failed on me yesterday. Not really sure what happened. Was trucking along, went to check on it and it's dead in the water. Strong burning smell and the motor is HOT. Hadn't noticed anything different about the way it was running although it had sat for about a month while I waited to get enough rocks for a batch. I'm a month out of warranty, but hoping that because it was a Christmas gift they'll honor a March 25 end date. If not, I guess I wait on another motor and hope it doesn't happen again. I've seen a couple of threads where Belt has either been very helpful, or not so much. Here's hoping for helpful!
ashley
Member since February 2023
Post by ashley on Mar 12, 2023 8:03:15 GMT -5
Oh nooo!! That’s horrible. I’m sorry to hear that. Praying they will honor the warranty and help you out.
jone
Post by jone on Mar 12, 2023 8:35:38 GMT -5
I hope you can salvage the rocks in that batch. If they don't honor the warranty then I see motors are not cheap ($126 at RockShed but sold out). This may be time to consider that MiniSonic. I'm still in the early learning curve on mine (and tumbling in general) but my initial impressions are favorable! Good luck!
Jon E.
Post by chris1956 on Mar 12, 2023 10:02:07 GMT -5
Sad to hear of another victim of bad motors. If they don't replace under warranty, here is a link to a description I wrote up for using an alternative motor that cost about $40. Requires some elbow grease to make changes. I have been running the new motor for about 10 weeks now and it is still running great. The Rock Shed has been running the same motor off and on since last summer without issues (last time I checked in January). forum.rocktumblinghobby.com/thread/101261/lot-tumbler-motor-modificationsChuck at Drumond Island Rocks has been running the same motor modification for probably a month or more without issues. Here is a link to his original post. forum.rocktumblinghobby.com/thread/101420/lot-motor-concrete-videoHope it works out well and you get a new motor under warranty.
rocknewb101
Post by rocknewb101 on Mar 12, 2023 12:22:22 GMT -5
Oh nooo!! That’s horrible. I’m sorry to hear that. Praying they will honor the warranty and help you out. Thanks ashley - I hope so too.. I hope you can salvage the rocks in that batch. If they don't honor the warranty then I see motors are not cheap ($126 at RockShed but sold out). This may be time to consider that MiniSonic. I'm still in the early learning curve on mine (and tumbling in general) but my initial impressions are favorable! Good luck! Jon E. I was able to get them out, rinsed and in a bucket of water for now. It had only been running a few hours when that happened so they weren't thickly covered. I'm already thinking about that mini sonic lol, but will try a new motor first - I do really like the lot-o. Sad to hear of another victim of bad motors. If they don't replace under warranty, here is a link to a description I wrote up for using an alternative motor that cost about $40. Requires some elbow grease to make changes. I have been running the new motor for about 10 weeks now and it is still running great. The Rock Shed has been running the same motor off and on since last summer without issues (last time I checked in January). forum.rocktumblinghobby.com/thread/101261/lot-tumbler-motor-modificationsChuck at Drumond Island Rocks has been running the same motor modification for probably a month or more without issues. Here is a link to his original post. forum.rocktumblinghobby.com/thread/101420/lot-motor-concrete-videoHope it works out well and you get a new motor under warranty. Thank you! I did come across this info in my readings. My hubby is handy so he'd be able to do alterations if needed. Here's hoping whoever answers the phone tomorrow got out of bed on the right side!
Post by jasoninsd on Mar 12, 2023 12:46:21 GMT -5
Seriously...that sucks!! I really do hope they honor the warranty!!
Post by stefan on Mar 13, 2023 4:32:55 GMT -5
Sorry to hear this. I also hope they honor the warranty. I think the bigger issue is why such a quick failure? Was this a Fasco motor? I'm worried that even if they send you a new motor it is still not going to solve the true issue. THere is a batch of bad motors out there. I work manufacturing so I understand the supply chain issues currently strangling most manufacturers but this does not give them an excuse to put out garbage. Hope all works out for you. (I have a new mini sonic and have been very pleased with it so far).
rocknewb101
Post by rocknewb101 on Mar 13, 2023 7:04:12 GMT -5
Seriously...that sucks!! I really do hope they honor the warranty!! Thanks, Jason! (Love Dwayne BTW!!) Sorry to hear this. I also hope they honor the warranty. I think the bigger issue is why such a quick failure? Was this a Fasco motor? I'm worried that even if they send you a new motor it is still not going to solve the true issue. THere is a batch of bad motors out there. I work manufacturing so I understand the supply chain issues currently strangling most manufacturers but this does not give them an excuse to put out garbage. Hope all works out for you. (I have a new mini sonic and have been very pleased with it so far). Thanks, Stefan! I hope so too...I'll have to check on the existing motor to see what brand (they should come with lot numbers, I think??) hopefully that'll be different - leaning more and more towards that mini!
rocknewb101
Post by rocknewb101 on Mar 13, 2023 12:04:46 GMT -5
GREAT NEWS! They are honoring the warranty! I just need to send the motor back and they'll replace it. Thank the lord! I did purchase a loratone 3A because I've got two tumblers moving stage 1, but nothing moving later stages (as I wait on the vibe motor). So in an attempt to keep on trucking with tumbling I'm now the proud owner of a Nat Geo, Thumlers and Loratone...
Post by jasoninsd on Mar 13, 2023 12:47:28 GMT -5
GREAT NEWS! They are honoring the warranty! I just need to send the motor back and they'll replace it. Thank the lord! I did purchase a loratone 3A because I've got two tumblers moving stage 1, but nothing moving later stages (as I wait on the vibe motor). So in an attempt to keep on trucking with tumbling I'm now the proud owner of a Nat Geo, Thumlers and Loratone... That is SUPER great news Peta!!
rocknewb101
Post by rocknewb101 on Mar 13, 2023 12:53:40 GMT -5
GREAT NEWS! They are honoring the warranty! I just need to send the motor back and they'll replace it. Thank the lord! I did purchase a loratone 3A because I've got two tumblers moving stage 1, but nothing moving later stages (as I wait on the vibe motor). So in an attempt to keep on trucking with tumbling I'm now the proud owner of a Nat Geo, Thumlers and Loratone... That is SUPER great news Peta!! I'm quite pleased! She didn't even hesitate once I mentioned I didn't get it until Christmas day. Grateful.
rocknewb101
Post by rocknewb101 on Mar 22, 2023 17:44:46 GMT -5
Happy to report that I'm vibin' once again different motor, but installed easily and the little fans fell right in place. Hopefully in about 5 days I'll have a nice batch of round and shiny rocks to share.
Post by perkins17 on Mar 22, 2023 19:28:39 GMT -5
Happy to report that I'm vibin' once again different motor, but installed easily and the little fans fell right in place. Hopefully in about 5 days I'll have a nice batch of round and shiny rocks to share. Good to hear. Keep enjoying the lotto.
dirtsifter
Co to za kamyczek?
Member since September 2022
Post by dirtsifter on Mar 23, 2023 0:25:29 GMT -5
GREAT NEWS! They are honoring the warranty! I just need to send the motor back and they'll replace it. Thank the lord! I did purchase a loratone 3A because I've got two tumblers moving stage 1, but nothing moving later stages (as I wait on the vibe motor). So in an attempt to keep on trucking with tumbling I'm now the proud owner of a Nat Geo, Thumlers and Loratone... The equipment and tools build up sooo fast. It's like they were tribbles or something. Glad to hear of the warranty replacement. My obsession started about this time last year with a single 1.5 lb tumbler from 1977 that I got used over 30 years ago. It was like a virus that I had contracted mildly back then, then BAM! Full blown last March. LOL
rocknewb101
Post by rocknewb101 on Mar 23, 2023 6:56:04 GMT -5
GREAT NEWS! They are honoring the warranty! I just need to send the motor back and they'll replace it. Thank the lord! I did purchase a loratone 3A because I've got two tumblers moving stage 1, but nothing moving later stages (as I wait on the vibe motor). So in an attempt to keep on trucking with tumbling I'm now the proud owner of a Nat Geo, Thumlers and Loratone... The equipment and tools build up sooo fast. It's like they were tribbles or something. Glad to hear of the warranty replacement. My obsession started about this time last year with a single 1.5 lb tumbler from 1977 that I got used over 30 years ago. It was like a virus that I had contracted mildly back then, then BAM! Full blown last March. LOL hahaha! The struggle is REAL! I've pretty much taken over the basement between tumblers and my little slant cab station - it's crazy how that happens
