leisa
Member since January 2015
Post by leisa on Mar 12, 2023 10:11:03 GMT -5
Post by hummingbirdstones on Mar 12, 2023 10:45:40 GMT -5
leisa
Post by leisa on Mar 12, 2023 11:16:13 GMT -5
Post by hummingbirdstones on Mar 12, 2023 11:17:53 GMT -5
YAY! It worked.
Post by stefan on Mar 13, 2023 13:45:12 GMT -5
THe spacers are WAY too small. The barrels will easily climb those. I'm guessing they are also eating away at the edge of the barrel as they are too tight between the shaft covers. There is no give and they just chomp away at the rubber. The shaft covers also look very worn which is probably not helping matters. I would take them apart and clean it all up. Replace all the worn rubber on the shafts and get taller spacers. Very cool setup
leisa
Post by leisa on Mar 13, 2023 15:46:40 GMT -5
Thank you - I will share the info with my brother who built the tumbler. Yes, the barrels (Thumler 3lb and Lortonr 6lb) were being "eaten."
kokosnood
Member since April 2020
Post by kokosnood on Mar 15, 2023 20:47:00 GMT -5
Are those 4 foot x 3/4 inch rods?
