icewlf
Member since December 2022
Post by icewlf on Mar 15, 2023 20:32:17 GMT -5
I've got a few more questions on my reworking of my Rock's Cabber. I'm swapping out the grinding wheel, and the new one I got is a bit thinner than the old one at the center. THe nut on the end of my arbor won't go all the way to the bushing I have against the wheel. The wheel as it sits is very tight on the arbor. Do i need a spacer between it and the nut?
If I do need a spacer, does anyone know if a small piece of PVP pipe, or something like that will work acceptably, or should I buy spacers from Kingsley or covington or another source?
THanks for the help again!
Post by manofglass on Mar 15, 2023 23:59:34 GMT -5
Don't use anything that will press into the wheels I used shaft collars
Post by Rockoonz on Mar 16, 2023 1:41:09 GMT -5
If there are flanges on the wheels a plastic spacer should be fine as long as you can get the ends good and square. If it doesn't have flanges I would get some. If you don't need a very long one a short stack of washers will also work.
