Post by stardiamond on Apr 20, 2023 13:57:37 GMT -5
hoolligan1938
Member since January 2022
Post by hoolligan1938 on Apr 20, 2023 17:16:11 GMT -5
Be sure and show them to us when you have them finished. Nice patterns and good looking stones.
Jim
Post by stardiamond on Apr 20, 2023 18:28:33 GMT -5
aGates
Building a silver studio
Member since January 2021
Post by aGates on Apr 20, 2023 22:31:44 GMT -5
hoolligan1938
Post by hoolligan1938 on Apr 21, 2023 10:51:24 GMT -5
Those are beautiful! They turned out great. Did you use a vibe for your polish stage or a wheel?
Jim
Post by stardiamond on Apr 21, 2023 14:07:26 GMT -5
I only have wheels and pads.
markb
Member since May 2022
Post by markb on Apr 21, 2023 22:20:36 GMT -5
stardiamond Great looking cabs! hmm, I noticed you left a fair amount of material beyond the black shape marking. I have a few stones I had cut out on my trim saw and I cut right up to the outside of the line. So, I guess this mean mine will be much smaller than what I originally wanted?
Post by stardiamond on Apr 22, 2023 10:31:12 GMT -5
My precision when using the trim saw is not perfect. I draw on top for the design, trim and then redraw on the reverse using a finer marker. I can move the template around in case I cut too close to the line or see a problem, vug or fracture. I grind from the reverse. I see top cabbers grind from the top but that would be more than challenging for me. I am self taught and developed my own technique. I grind the preform and the edge flares out to the top. I mark the girdle line and dome. I then grind the edge square rotating the edge vertically. The bottom is protected and so is the face.
