Post by stardiamond on May 17, 2023 16:46:27 GMT -5
I sit in a chair on my deck smoking cigars and looking at rocks. Yesterday, I worked on the mess and tossed trash and rocks that I wouldn't give away. I found a bone slab, a crazy lace slab and an opalized Biggs preform that needed a little more grinding. I dopped these with a Dead Camel and a Rainforest that I had trimmed but needed to have the preform ground.
Post by stardiamond on May 18, 2023 17:14:23 GMT -5
Post by Son Of Beach on May 18, 2023 17:21:45 GMT -5
You're on fire lately!
Always love your displays
Post by realrockhound on May 18, 2023 17:46:56 GMT -5
Better slow down, you’ll end up grinding your fingers off at that rate.
Post by stardiamond on May 18, 2023 18:19:21 GMT -5
The weather is good. I think I need to straighten out my work area, dump my Covington, set up my new HP 14, and start slabbing.
I had two lessons on cabbing and was taught to dop with wax. I got so tired of cabs coming loose, I went dopless. When I was working I only cabbed on the weekend which gave me 5 days for my fingers to heal. I now dop with superglue and use a combo technique. I only use the dop when my fingers could get ground.
khara
Member since September 2022
Post by khara on May 18, 2023 19:52:15 GMT -5
Do you undop with acetone, or freezer method? I’ve been using acetone. It works but I don’t like the goopy mess left from the partially dissolved glue or the white film that can be left on the cab, I think from the dissolved glue in the acetone leaving a really thin layer on the stone. It seems to wipe/wash off but I keep thinking maybe it’s not great for the stones. The freezer though also sounds not great for some stones.
Post by realrockhound on May 18, 2023 19:57:38 GMT -5
Do you undop with acetone, or freezer method? I’ve been using acetone. It works but I don’t like the goopy mess left from the partially dissolved glue or the white film that can be left on the cab, I think from the dissolved glue in the acetone leaving a really thin layer on the stone. It seems to wipe/wash off but I keep thinking maybe it’s not great for the stones. The freezer though also sounds not great for some stones. Blow torch. Pops right off
Post by stardiamond on May 18, 2023 20:13:39 GMT -5
Do you undop with acetone, or freezer method? I’ve been using acetone. It works but I don’t like the goopy mess left from the partially dissolved glue or the white film that can be left on the cab, I think from the dissolved glue in the acetone leaving a really thin layer on the stone. It seems to wipe/wash off but I keep thinking maybe it’s not great for the stones. The freezer though also sounds not great for some stones. I gave up freezing. I gave up on popping them off (occasional divots). I use an x-acto chisel blade and put the flat side against the cab and tap on the x-acto holder with a utility knife until the cab separates from the dop. My dops are made from dowels with a nail on chair glide. When the cab comes off, I use a q-tip and acetone to loosen the glue and then scrape it off with a chisel blade.
khara
Post by khara on May 18, 2023 21:38:22 GMT -5
realrockhound stardiamond Ok, thanks both of you. I’ll try those methods. I also don’t like the soak wait time that I’m currently doing. My dop sticks are mostly wooden dowels with a large headed nail in the end.
Post by stardiamond on May 18, 2023 22:04:50 GMT -5
The nail works well with the torch. I don't have a torch.
rocknewb101
Member since October 2022
Post by rocknewb101 on May 19, 2023 8:39:01 GMT -5
stardiamond I'm curious why you gave up on the freezer method? Are there issues doing it this way? I often only have to have it in there for minutes before it pops right off - could I be damaging the rock? Or is it more the potential for it to crack?
Post by stardiamond on May 19, 2023 11:26:11 GMT -5
It might be my dop sticks, but it wasn't an effective method for me. Leaving the dops in the freezer for a long time produced cabs that separated themselves, some with almost no force and stubborn ones. Even the ones that required little force occasionally produced divots. I sometimes had to remove glue residue.
What I do now can be done immediately after finishing the cab and doesn't damage the cab.
Post by stardiamond on May 19, 2023 12:33:30 GMT -5
Post by stardiamond on May 19, 2023 13:17:19 GMT -5
adrian65
Member since February 2007
Post by adrian65 on May 19, 2023 22:22:35 GMT -5
It's great to see them as pre-forms and then as finished cabs. Very colourful, eye-catching group!
Adrian
