blondie25
Member since July 2023
Post by blondie25 on Jul 5, 2023 23:14:20 GMT -5
Hello!
I need help with using the polisher pads on my Bench Grinder. I want a shiny finish on rocks too big for my tumbler. How would you achieve this? Certain kinds of pads maybe? I tried with the pad it came with and nothing. The grinder is great though.
Post by vegasjames on Jul 6, 2023 0:27:45 GMT -5
Welcome to the forum.
You would need to get the stones fairly smooth to begin with. Then I suggest using a cotton buffer wheel. Peel back some of the paper tube of a tube of Zam and while the wheel is spinning, lightly push the exposed Zam against the wheel. The friction will melt a little the Zam on the wheel. Then buff the stone with the wheel. Repeat apply a little of the Zam once in a while. Adding too much will leave a dull, waxy coat, which s why you want to lightly apply the Zam to the wheel.
blondie25
Post by blondie25 on Jul 6, 2023 19:39:47 GMT -5
Welcome to the forum. You would need to get the stones fairly smooth to begin with. Then I suggest using a cotton buffer wheel. Peel back some of the paper tube of a tube of Zam and while the wheel is spinning, lightly push the exposed Zam against the wheel. The friction will melt a little the Zam on the wheel. Then buff the stone with the wheel. Repeat apply a little of the Zam once in a while. Adding too much will leave a dull, waxy coat, which s why you want to lightly apply the Zam to the wheel. Great I'll try that! Thank you!
