Post by stardiamond on Jul 12, 2023 17:11:19 GMT -5
I had a couple and they disappeared. I use them to photograph. I bought some rock/slab stands but the bottom is curved and the cabs do a dance. I bought some easels from Amazon and they were way to big. I have a smaller one but it doesn't work with small or narrow cabs.
I've checked Amazon, ebay, etsy, johnson brothers, Kingsley North, Rock Peddler and Fire Mountain.
Post by Pat on Jul 12, 2023 17:31:26 GMT -5
Try nilecorp.com
Post by stardiamond on Jul 12, 2023 17:48:11 GMT -5
Thanks, I looked. Baseballs, hot wheels no easels for small objects.
Post by Pat on Jul 12, 2023 17:55:34 GMT -5
Typo. Should be nilecorp.com
khara
Member since September 2022
Post by khara on Jul 12, 2023 18:00:04 GMT -5
I’m not sure what shape you are looking for exactly but would it be buildable? Using the plexiglass from the hardware store and a heat gun to bend it? We’ve used this to make guards for our machines. Maybe a thinner sheet could be cut and bent to hold a cab?
realrockhound
Chucking leaverite at tweekers
Member since June 2020
Post by realrockhound on Jul 12, 2023 18:05:46 GMT -5
Could be ghosts. They are always moving my stuff.
Post by HankRocks on Jul 12, 2023 18:29:26 GMT -5
Post by stardiamond on Jul 12, 2023 18:39:40 GMT -5
I’m not sure what shape you are looking for exactly but would it be buildable? Using the plexiglass from the hardware store and a heat gun to bend it? We’ve used this to make guards for our machines. Maybe a thinner sheet could be cut and bent to hold a cab? I bought 20 or these from Amazon. The problem is the base is arced and slopes forward. I decided to sacrifice one as an experiment. I heated it with a triple flame torch lighter hoping to adjust the tilt and it just collapsed. I can put a piece of double sided exterior tape on it so the cab won't move, but the tape looses the stick quickly. Plan b, is to grind a notch using a Dremel. Maybe I'll try the tape.
Post by stardiamond on Jul 12, 2023 18:42:11 GMT -5
I have one of these and it works fine for larger cabs, but the small ones fall trough the gap.
rockbrain
Member since January 2022
Post by rockbrain on Jul 13, 2023 17:39:51 GMT -5
stardiamond I've got them from Here. I think you've dealt with Johnson Bros so it may be a bit of a wait. They have the tiny triangular ones. 1.5" x 1.25". How many are you looking for. I might have a few extras.
Post by stardiamond on Jul 13, 2023 18:19:36 GMT -5
The problem with the small easels is that are still too wide for small cabs. I had some of the larger ones I just bought on Amazon. Amazon also has the small ones. I took a butane jet lighter to one. Next step is too chop the top with a saw.
Post by stardiamond on Jul 24, 2023 16:35:00 GMT -5
I have a large ziploc bag full of acrylic stands for slabs, spheres, etc. I thought I had looked in it for cab stands before. I checked and found these: I now have four so I don't need to look further. The one on the right is all I could find and they are designed for slabs.
Post by Pat on Jul 24, 2023 17:37:01 GMT -5
Do you remember Stoner(Ed)? He hasn’t been on the forum for ages.
He made exquisite cabs. To photograph them, he placed them on a frosted translucent squirrel.
Let me explain. The squirrel was a candy dish with a lid. The squirrel was the lid handle. The base was a basket made of the same material.
He turned the lid upside down, and propped the cab there. Worked perfectly.
I couldn’t find any of his threads or contributions on my cellphone.
My point is you don’t need official stands. Good luck!
