kd8cns
Member since May 2023
Post by kd8cns on Aug 17, 2023 14:46:47 GMT -5
Good afternoon, I am new to my Lot-o-tumbler and have had a few batches that get a blob of grit in the bottom of barrel. Ceramics and grit come to a sludge in the bottom and are hard to get out. What am I doing wrong? Thnx Bill
Post by chris1956 on Aug 17, 2023 16:31:16 GMT -5
Could you share some additional information such as what grit or polish it is clogging on? If on pre- or polish, do you use borax? How much ceramics do you use? Are you adding water or just getting rocks and ceramics wet? etc.
You can also probably do a search for Lot-o. There have been discussions in the past about stuff clogging on the bottom but it may take some time to find them.
Thanks
ashley
Member since February 2023
Post by ashley on Aug 17, 2023 17:12:23 GMT -5
Your not doing anything wrong it happens. Mostly on 120/220 but sometimes at 500 too. How much grit are you using? Make sure to check it often on the first day and use a spray bottle to give it a good mist so it has the consistency of yogurt.
dillonf
Hounding and tumbling
Member since February 2022
Post by dillonf on Aug 17, 2023 20:04:41 GMT -5
I've had it happen when the tumble is too dry. As ashley said it is more common in the 220 or 500 stage when the slurry gets thick.
