lapidary1234
Member since October 2021
Post by lapidary1234 on Aug 17, 2023 18:04:10 GMT -5
Hi all, just found this in an old envelope and thought someone might get a kick out of it!! Looks like the cost of all parts added together equalled around $37 49 years ago...my how the times have changed! Anyways enjoy : ) ~Josh
dillonf
Hounding and tumbling
Member since February 2022
Post by dillonf on Aug 17, 2023 19:52:49 GMT -5
Oh-man. That is cool!
iamchris
Member since June 2023
Post by iamchris on Aug 18, 2023 8:50:18 GMT -5
That's wild. Not all the parts are still available, but I matched them up against current day prices for anyone else also curious. The cumulative rate of inflation of the USD since 1974 is 520.1% for reference. I can't believe they used to have a switch! I'm definitely going to modify mine and install a switch in the location pictured. Thank you for posting!
lapidary1234
Post by lapidary1234 on Aug 18, 2023 12:57:03 GMT -5
Yes, the mine dies have a switch! Didnt even think to post a pic of it...here you go, for what its worth I have seen one with the switch oriented a different direction as well, and I have seen a few older lortones w/o the switch. Also, there is VERY little slack in the wiring to the switch, if I ever replace the motor I will definitely add a little extra wire to give it a little slack!!
