adam5
Member since August 2023
Post by adam5 on Sept 2, 2023 11:36:27 GMT -5
Warts and all: All of these were found locally, except for the dark red one which came from a bag of beach rocks bought at Lowe's and the small jaspers(?). The two rosy quartzs only have a dull shine, perhaps because my TV-5 vibrates a bit too vigorously. And the green rock, which I thought might be epidote, did not polish up at all. Still much to figure out.
jimmie
Member since August 2021
Post by jimmie on Sept 2, 2023 12:17:16 GMT -5
Good job!
Post by velodromed on Sept 2, 2023 12:29:55 GMT -5
Nice job, and don’t stress, you’ll have many subpar shines before you get your system down. Took me nearly a year to figure it out. I do all my course tumbling in rotary tumblers for as long as needed to get the quality and shape I want. I do stages 2-polish in my raytech 5. The action is fairly rough, so for SiC stages I load it down with a combo of smaller aquarium agate and mixed sized ceramics. For AO pre-polish and polish I use a separate bowl, lid and all smaller sized ceramics. Whichever bowl it is, I load it 1/2-3/4ths inch from the top. I also use a minimum amount of grit. Only a tsp or so of 200 range SiC and 3/4s tsp of 500 or 600 SiC. For the pre polish and polish stage I first add 3/4ths tbs of borax, then 1/2 tsp of 1200 or 1500 AO for pre-polish, and 1/4th tsp of .2/3 micron AO. Each of these stages are run 2-3 days. After the course stages in the rotary, I run a cleaning stage for a few hours in the vibe with a few drops of dish soap. I also do this after each SiC stage in the vibe, and twice before moving to pre-polish and between pre-polish and polish stages. Lastly, after the final polish stage cleaning, I run a borax only stage (burnish) for a few hours with 1 tbs borax. I have a batch finishing this afternoon and will post it later. Below is how high I load it…
Post by chris1956 on Sept 2, 2023 12:46:47 GMT -5
Nice. Quartz can be hard to get a good polish.
Post by jasoninsd on Sept 2, 2023 23:31:16 GMT -5
Nothing to be disappointed about in that first batch!! Way to go!!
michiganpebbler
Member since April 2023
Post by michiganpebbler on Sept 3, 2023 10:20:39 GMT -5
You did great for your first tumble! It’s takes time to dial it all in, and you’ll get there. Well done!
adam5
Post by adam5 on Sept 3, 2023 13:20:21 GMT -5
Thanks for the encouragement velodromedMy process at the moment is much like yours, only that I go from 500 AO directly to AO polish (from the Rock Shop). I am having trouble with keeping the moisture level right. I am normally gone from home between 5 am and 5 pm and my tumbling area is in my shed. The rocks in the TV-5 tend to be seized up when I get home. I am using weather stripping between the bowl and the lid to help against evaporation, and it has helped. But the rocks still aren't moving much when I get home.
Post by Starguy on Sept 3, 2023 14:59:27 GMT -5
Nice looking batch. Did you do some rotary tumbling with them too?
adam5
Post by adam5 on Sept 3, 2023 16:06:14 GMT -5
Thanks!
Yes. They started out in Chicago Electric 3 lb barrels for grinding/shaping before going on to the vibratory tumbler.
Post by velodromed on Sept 3, 2023 17:50:49 GMT -5
Thanks for the encouragement velodromed My process at the moment is much like yours, only that I go from 500 AO directly to AO polish (from the Rock Shop). I am having trouble with keeping the moisture level right. I am normally gone from home between 5 am and 5 pm and my tumbling area is in my shed. The rocks in the TV-5 tend to be seized up when I get home. I am using weather stripping between the bowl and the lid to help against evaporation, and it has helped. But the rocks still aren't moving much when I get home. It’s really bad for the rocks when they seize up dry and all. This is a big reason why I use small amounts of SiC grit, especially if it’s in the 200 range and lower. It’s just easier to control. So that’s why I’ll only use a level teaspoon or less at first. I can add 1/2 a tsp the next day or whenever. I also keep it loaded 1/2” from the top with ceramics and small agate so the rocks don’t vibrate so hard against each other. I’ll add extra water before unmonitored stretches. It’s definitely a juggling act. I don’t use anything between the lid and bowl. I do not tighten the bottom rubber nut as much as recommended, because if you do, it flairs out and prevents the lid from firmly setting on the bowl. I tighten the top rubber nut down pretty firm and spin the lid down tight, to where there’s no vibration. This seals the lid against the bowl and prevents evaporation also.
adam5
Post by adam5 on Sept 11, 2023 20:40:52 GMT -5
I had another go at some of my 1st rocks to make it through polish, as well as some other rocks. Using velodromed's recipes as a guide, I made some adjustments to my use of the RayTech TV-5. I am happy with the results.
dshanpnw
Member since December 2020
Post by dshanpnw on Sept 12, 2023 6:48:02 GMT -5
Nice 1st batch. I'd say you are definitely off to a very good start. If I see that a some of the stones look like they are not going to shine after the 500 stage I remove them so they don't contaminate the later stages. Thanks for sharing.
