MetaMoose
@MetaMoosehead on Twitter
Member since July 2021
Post by MetaMoose on Sept 4, 2023 9:30:15 GMT -5
Hey folks, The white bearing sleeve on the unpowered rail of my lortone (33B I believe) seems to be slipping - they are not supposed to spin (the other three are unmoving), but it is starting to slip out of position somehow, and when it does it begins to rotate with the shaft producing a wobbling noise that doesn’t sound healthy. I can pop it back into place to a degree and it seems to hold for a bit. But it did pop back out again - so I’m guessing that bearings sleeve is failing. I’m hoping this is a maintenance issue others have faced. Are these bearing sleeves easy to replace? Images: imgur.com/gallery/sBZXlx9
Post by Deleted on Sept 4, 2023 9:43:01 GMT -5
Time
Making something positive out of COVID restrictions by learning to create jewelry out of stones.
Member since September 2021
Post by Time on Sept 4, 2023 10:05:45 GMT -5
I think you can just order one from Kingsley North and pop the old one out and a new one in. If it is on the motor side it will be a little harder but doable.
MetaMoose
Post by MetaMoose on Sept 4, 2023 10:07:58 GMT -5
Hey there CR! You’ve been a great help to me in the past, through your YouTube channel. I’ve been subscribed for some time. I’ve most appreciated your advice on the GaiaGPS app. It’s been such a help! This tutorial is exactly what I was hoping for - thank you. The shopping list of parts does not come with links, so I am shooting from the hip a little with the bearings. I’m thinking these fit the bill? uxcell F688-2RS Flanged Ball Bearing 8x16x5mm Double Sealed Chrome Steel Bearing 10pcs a.co/d/jaSaxtN
MetaMoose
Post by MetaMoose on Sept 4, 2023 10:08:49 GMT -5
I think you can just order one from Kingsley North and pop the old one out and a new one in. If it is on the motor side it will be a little harder but doable. Ok that’s helpful, thank you!
