rockbobby
Member since October 2023
Post by rockbobby on Oct 12, 2023 8:37:57 GMT -5
Hello there, I am fairly new to rock tumbling. I have had mixed results, steady improvement with research; however, I can not seem to find a good answer to what is the best way to get a good polish on rocks that come out less than ideal?
The real question: is it advisable to redo the last grit tumble or simply work on the polish?
Any information on re tumbling rocks and polish would be great- help start filling gaps in my knowledge.
Thank you!
Post by chris1956 on Oct 12, 2023 12:22:51 GMT -5
rocknewb101
Member since October 2022
Post by rocknewb101 on Oct 12, 2023 15:11:17 GMT -5
Hi rockbobby . I had the same issues starting out. Mine boiled down to crappy polish and trying to tumble rocks that weren't beginner rocks (moonstone). What kind of polish are you using? If it's only 1000 or 1200 grit it may not be high enough grit to really get the job done. I use 8000 grit (mesh, whatever it's called lol) that I get from the rockshed. You can get it elsewhere too, but I've never seen it on amazon. With my moonstone, it came out all bruised, frosty and not shiny at all. I realized I hadn't used enough ceramic media in the stages to help cushion the rolling rocks. About a year later I decided I wanted to try and put them through again. I started with a short 2-3 days in stage 1, then moved along to stage 2, 3 and polish. They were still cracked (nothing will fix that!) but I managed to get a decent polish on them and redeemed them somewhat. So, long story short - you most certainly can put your rocks back through the stages - I'd recommend at least going back to 120/220 grit, especially if they are already rounded nicely. What are you tumbling? If your rocks are softer, make sure you are adding in some kind of ceramic media to help cushion them. good luck! Would love to see pics of what you're working on. **As an aside - softer rocks can be harder to polish than agates or jaspers so don't get discouraged if you are only seeing a matte/satin finish - sometimes that's all you get
dshanpnw
Member since December 2020
Post by dshanpnw on Oct 12, 2023 17:55:48 GMT -5
welcome to the forum from Washington state, our state gem stone is petrified wood. I second everything Rocknewb101 stated.
dillonf
Hounding and tumbling
Member since February 2022
Post by dillonf on Oct 12, 2023 19:55:25 GMT -5
Welcome. There are plenty of folks willing and able to help you out! Start with what rocknewb101 suggested and give us some more details on the rocks you are tumbling, type of tumbler and type of grit you are using.
Post by jasoninsd on Oct 13, 2023 6:33:44 GMT -5
Welcome to the forum from South Dakota! Looks like there's been some good advice given to steer you in the right direction!
michiganpebbler
Member since April 2023
Post by michiganpebbler on Oct 13, 2023 10:01:04 GMT -5
Welcome from lower Michigan! You’ve come to the right place for information!
