llanago
Member since January 2004
Post by llanago on Dec 27, 2004 19:10:55 GMT -5
All my burrs/bits are so dull they wouldn't drill hot butter! I need some advice/info on what kind I should get. I have been using 40 grit diamond burrs and some bits I got at the rock show this past spring. Once I got to drilling it didn't take long to use them all up! Sands or somebody posted a link to a package of 25 that I was looking at but forgot to save the page! llana
Post by cookie3rocks on Dec 27, 2004 19:59:09 GMT -5
Post by docone31 on Dec 27, 2004 20:42:26 GMT -5
Are you lubricating your bits? They are also more for the speed of a full tilt dremel than with a shaft, or a foredom. Bits are for using fast and lightly, with a parafine lube.
Post by cookie3rocks on Dec 27, 2004 21:48:41 GMT -5
Doc, What's a parafine lube? You allways make us dig for the truth, you sly fox cookie
llanago
Post by llanago on Dec 27, 2004 22:20:55 GMT -5
Doc, I lubricate with water with a bit of borax in it and drill at the highest speed. I also do the pulse thing you said to do on another post way back when.
Weah, what is a parafine lube?
llana
JKowalski33
Member since August 2004
Post by JKowalski33 on Dec 27, 2004 22:21:31 GMT -5
i got a dremel model 800 which has a battery and charger so it is cordless, its nice. it goes up to 35,000 rpm, i remember people talking about certain speeds to use for the best efficiency of the burrs. how fast should i be using the diamond burrs at?
Post by sandsman1 on Dec 27, 2004 23:33:42 GMT -5
Post by docone31 on Dec 27, 2004 23:37:50 GMT -5
Jewelers use it on their bench for burrs. It is blue, comes in either a tube or button for the bench. It really is wonderful stuff. It is parafin based, has some silicone, is Lamar blue, and lasts forever. Rio has it. It is in either a tube or comes on a button that screws to the bench.
Post by Cher on Dec 28, 2004 0:39:19 GMT -5
Nice Sands, would those fit in a dremel?
Cher
Post by docone31 on Dec 28, 2004 8:18:17 GMT -5
Dremel makes a chuck for the tool. It replaces the four collets and is pretty handy.
Post by sandsman1 on Dec 28, 2004 8:50:24 GMT -5
yea cher docs right they have a micro chuck i think its called and it will fit alot of small sizes and they should fit --its not expensive under ten bucks i think www.micromark.comitem #81049
