Post by Cher on Jan 6, 2005 10:31:37 GMT -5
Found last night that the router speed control that Doc told us about (for slowing down a grinder's rpms) is on sale. I had checked before Christmas, they were $25.00 and last night I bought mine for $9.99 so if anyone is looking, now's the time. Don't know if this link will work since it's for an item search router speed control but if it doesn't just go to www.harborfreight.com and search for router speed control. Cher
Post by docone31 on Jan 6, 2005 14:26:17 GMT -5
That will work. I would start at full tilt, then slow down for the work needed. It also works with the dremel, an other tools.
Post by Cher on Jan 6, 2005 14:40:19 GMT -5
Full tilt? I thought the grinder needed to be slowed down to around 1750 rmps? Cher
MichiganRocks
"I wasn't born to follow."
Member since April 2007
Post by MichiganRocks on Jan 6, 2005 14:51:51 GMT -5
Hey Cher, I think that doc meant that you should have it turned up to full speed when you turn your eqiupment on, and then lower the speed. Starting up at a reduced voltage can fry your motor.
Ron
Post by Cher on Jan 6, 2005 19:50:50 GMT -5
Ooooo DUH!! That makes sense, thanks. Sorry I was having a blond senior moment that lasted all day. ;D Cher
RedwoodRocks
Member since March 2003
Post by RedwoodRocks on Jan 6, 2005 20:07:05 GMT -5
Cher, Thanks for the tip. At 25 bucks plus shipping, I have put off buying. But, at $10 plus shipping, I should order.
Cal
Post by Cher on Jan 6, 2005 20:30:04 GMT -5
Yup, shipping is $5.95 so your still saving $10.00.
Cher
