Post by Tweetiepy on Jan 17, 2005 22:20:03 GMT -5
What do I need to get started tumbling a batch of stones? Grit: what kind / type? All I know is I had coarse, medium & polish in my kit - now that I have to get my own, what do i need to "start anew"? How long approximately in each substance? I've been doing: 2-4 days in the "coarse" 10-14 days in the "medium" 7 days in the polish I have no idea what each type "is" but I do know that the polish made a big fluffy "cream" like shaving cream in my barrel. Thanx everyone in advance for your help
RedwoodRocks
Member since March 2003
Post by RedwoodRocks on Jan 17, 2005 23:19:48 GMT -5
I use:
60 or 60/90 grit for coarse. The last batch I bought is the 60 grit. Read somewhere the grit is more consistent. This makes a lot of sense.
For the medium, I use 120/220 grit
For the fine grit, I am using 500 grit
For an extra step, I have been using 1000 grit, but have also bought tripoli on Master Polisher Jame's suggestion.
Polish - Aluminum Oxide, Cerium Oxide and Tin Oxide, I would also like to get some Titanium Oxide/Titanium DIoxide. I have gotten the best results with the Cerium Oxide, but this is a bit pricey. The Titanium Oxide or Titanium DIoxide is priced more reasonably. I just can't figure which one is better. (need to re-read the threads)/
Also, if you are going to buy in quantity, buy more of the coarse grit - 60 or 60/90. I usually keep my rocks in coarse for months at time. Thus, I go through the coarse grit very fast, the other grits and polish can be purchased in more modest quantities.
My two cents. Cal
llanago
Member since January 2004
Post by llanago on Jan 17, 2005 23:24:13 GMT -5
Rocks! 60/90 (coarse) grit 120/220 (medium) grit 500 (fine) grit/prepolish Polish - there are a number of different kinds of polish Extra barrel to be used only for polish A lot of patience Here's a link to the process James uses on his stones. If you haven't yet seen some of his finished stones, you need to check them out. Beautiful! BTW, welcome aboard! llana
WarrenA
Member since November 2003
Post by WarrenA on Jan 18, 2005 0:05:07 GMT -5
i think you will find that the usual time for each step is at least 1 week each or run the batch in coarse until YOU are satisified with them and then 1 week per step until polish then tumble until done whenever YOU like them. there is no magic but you will acquire patience
Post by rockyraccoon on Jan 18, 2005 0:13:35 GMT -5
i use the method cal described. my problem is i pull out the ones ready to move to 120/220 and put them aside waiting on enough stones to fill the barrel. then i put in more rough with the ones that were not ready and keep going at 60/90. and for some reason i just keep repeating that lol. i need to find all my little bowls of those ready for step 2 and move onward!! i think i've been on 60/90 forever!
kim
llanago
Post by llanago on Jan 18, 2005 0:33:44 GMT -5
Kim, that's what I do. I clean the rocks and barrels, so thru those that are ready to move on, add new ones to replace the old, then recharge and go. I kept forgetting about the ones I had pulled out to go to 220, so started making myself a note in my tumbling log so I wouldn't forget. I put them in a ziploc labeled "ready for 220 - need washing" or "washed - ready for 220". Since I started putting it in my tumbling log, I haven't forgotten about them! Of course, I just started doing that a few weeks ago after I discovered a gallon ziploc way back on the shelf ready for 220! Have no idea how long it had been there. llana
Post by rockyraccoon on Jan 18, 2005 0:59:45 GMT -5
i feel better llana that i'm not the only one . i'm gonna have to make this a priority to gather up the ones ready to move on and MOVE ON. i have 5 barrels all on 60/90 lol. kim
