momma
YUMMY
Member since December 2004
Post by momma on Jan 22, 2005 21:05:02 GMT -5
Hey Yall, Hows it going?
I have another question if you all could help. Ok, my agates have ben in the first stage tumbling for about 21days today. Only about 20 rocks were able to come out and there waiting for the others for stage two. I have rocks in the tumbler that are kind of lumpy. They dont have any cracks or crevices or anything like that there just lumpy. Can I take those out or should I leave them in untill there all round?
Any suggestions Please.
Thanks momma
Post by sandsman1 on Jan 22, 2005 21:13:39 GMT -5
hi momma when you like the shape then its time to move them on if they had cracks and holes id say let them stay another week and see,, but if they look good to you go for it
Post by Toad on Jan 22, 2005 22:22:06 GMT -5
Barring any 'defects', leave them as they are. The more shapes and sizes you have - the better results you get.
momma
YUMMY
Post by momma on Jan 24, 2005 11:32:42 GMT -5
Hey guys thanks for the info. really appreciate it. I did check on them again and I really like some of them with the lumps but I decided to put them back in, I will check on them again in a few days. Hopefully some will be ready to come out.
Another question is what would be the bast polish to use?
thanks: momma
Post by krazydiamond on Jan 24, 2005 11:59:31 GMT -5
that is a question we all struggle with, Momma. we all have our personal opinions but if you have nice hard rocks and the shape is good, Aluminum Oxide will work just fine. if you have stubborn or softer stones, try some Titanium Dioxide and you can NEVER go wrong with Tin Oxide, but that is a little on the pricey side.
good luck!
KD
momma
YUMMY
Post by momma on Jan 24, 2005 14:38:10 GMT -5
Thank you KD. What about using Lustrite II. I bought a pound of it at a rock and mineral show and he said it was a good polish but IM not sure if anyone has herd of or used it. Any ides on it?
Thanks
momma
Post by Noosh9057 on Jan 24, 2005 15:11:10 GMT -5
Hi there all just wanted to put my to cents in. I think Cerium Oxide Polish works great for hard Rocks. What do you all think about Cerium Oxide Polish?
Roger
Post by krazydiamond on Jan 24, 2005 19:41:14 GMT -5
i've never heard of Lustrite II to be quite honest as a polish for rotary tumblers, and Noosh, my experience with Cerium was not very good, but maybe i got the wrong grade?
i see where there are all different kinds..optical grade? i bought some fairly inexpensive stuff and i think it maybe more of a pre polish than anything..but i really dont know.
Momma, try some cheap and cheerful AO (Aluminum OXide) and go from there, my opinion,
KD
Post by connrock on Jan 24, 2005 19:46:30 GMT -5
KD, Were you prepolishing as you do now? Did you let the polish cycle run as long as you do now?? Cerium ain't all that bad. Tom
Post by cookie3rocks on Jan 24, 2005 19:49:44 GMT -5
Momma, I say use the stuff you bought and let us know the results. The only thing that could happen is they have to got through polish one more time, and what's another week? I also like cerium oxide on agates. Have gotten some beautiful results. I have also used optical grade CO and it was like icing on the cake. Good luck!
cookie
momma
YUMMY
Post by momma on Jan 24, 2005 20:57:03 GMT -5
Thanks for the info everybody. I wrote everybodys opion on the polish down so I can at least go out and buy it. I have right know AO so I will use that and see what kind of results I get and let yall know. The Lusterite II that I have when I was using it on my rocks the kidos found in the yard did not polish those, so maby I should have used the AO to see if they would polish. OOOHHHH well, but I will see what happens with this and post them good or bad to see what they look like. Thanks everyone.
momma
bwalters
Member since March 2004
Post by bwalters on Jan 24, 2005 21:09:16 GMT -5
Momma, I've never tried Lustrite II either, but I have to agree with Cookie. If your stones are ready for polish, I would try it and see if you like the results. We're all constantly experimenting. Please let us know how your experiment turns out!
BE
