BearMountain
Post by BearMountain on Jan 25, 2005 15:38:58 GMT -5
A newbie question: does anyone know how to tumble polish glass up to 'water clear?" I have been fire polishing dichro-but it is too thick (1/4 inch) and I want to grind it down and then put in in a Berry's vibro and polish all the way back to 'perfect' for jewelery. The problem is that dichro glass is really a metalic colored glass capped with a layer of clear. A wonderful man at Covingtons said I would have better luck with a belt sander, but these are small bits of glass and hard to hold. The guy swears its impossible to get the clear glass back to they way it looks when it comes out of the kiln. Any suggestions at all would be helpful.
Post by sandsman1 on Jan 25, 2005 15:48:03 GMT -5
hi bear im not a pro but i would think the best way would be to use diamond paste up to about 50000 on felt wheels on a grinder then some optical cerium to polish --- iv never done it but that seams like the way to go ---what iv herd about tumbling is it frost the glass so you would be going in the wrong direction if you tumble
Post by hermatite on Jan 25, 2005 16:34:40 GMT -5
Stevek
Member since December 2004
Post by Stevek on Jan 25, 2005 17:54:54 GMT -5
Post by connrock on Jan 25, 2005 21:10:52 GMT -5
Hi Bear, Moh's Gemstone Hardness Scale,,, www.orionsgemz.com/Mohs.htmlputs glass at 5-6 and obsidian at 5 so you should be able to get a mirror shine to your glass if you tumble it as obsidian (volcanic glass). Tom
Post by BearCreekLapidary on Jan 26, 2005 14:09:18 GMT -5
Hello Bear Mountain,
I have had some good results with glass. I use Tripoli as a prepolish and then go with Tin Oxide as a final polish.
I use a vibe tumbler and I have been satisfied with my results.
Hope this helps,
John
BearMountain
Post by BearMountain on Jan 26, 2005 16:00:41 GMT -5
:)Thank you so much everyone for helping me the the glass question. I have a lot of things to try now and am very excited to get going, rather than discouraged as I was before.
Post by connrock on Jan 28, 2005 17:19:45 GMT -5
Hey Bear don't get discouraged with anything you try to tumble. When I started all I had was a small book and a few great people I met on the web.There was nothing like this site and believe me I went through hell making more mistakes theen you can imagine.I wasted masses of grit and polish and once I even had a lid literally blow off a tumbler and there was slury and rice all over my shop! I've been discouraged by other things in life which caused me to loose interest in tumbling but I always got back and dug right in. Don't ever get discouraged Bear,,,,,,,,,, We're hear to help and help we will! Tom
Post by Joan on Jan 29, 2005 20:53:22 GMT -5
What a wonderful note, Tom. Thank you, thank you everyone for such great encouragement.
