Post by Kassie on Jan 28, 2005 20:40:41 GMT -5
This is my first time tumbling and tomarrow I'm change the grit from 80 to 60. Are the rocks supposed to look different then when I first put them in?
Oh and can I tumble tigereye and hematite together?
Banjocreek
Member since March 2003
Post by Banjocreek on Jan 28, 2005 21:12:02 GMT -5
I think I might rethink that there Kassie, cause it sound like you are going backwards. You should be getting all the pits out and the rocks edges worn in the 80 then go to something like 120/220. You want the number to get bigger on the grit size, not smaller.
Post by docone31 on Jan 28, 2005 22:26:47 GMT -5
Hematite and Tigereye tumble real well together. Grits almost always, if not always go from small number for coarse, to large number for fine. You would go from 80 to 120, or 220. It doesn't hurt to let the tumbler run a little longer in each cycle. Sign up, join us, you will learn a lot.
Post by stefan on Jan 29, 2005 15:23:48 GMT -5
Like the others said- grid gets finer as the numbers get bigger- and your rocks should look different than when they went in- they should be smoother- pits and chips shold be gone and you should notice a nice luster when they are wet- Hope this helps- and join up- the people here are an amazing wealth of knowledge and advice
Post by Kassie on Jan 29, 2005 16:48:05 GMT -5
ok thanks ;D
Post by connrock on Jan 29, 2005 17:23:10 GMT -5
Hi Kassie, It's nice to have a guest but why don't you jump in and join us?? Don't worry about making mistakes.We've all been there and done that!The only difference is now you have us to help you not make the same ones we did! Tom
