grayfingers
Member since November 2007
Post by grayfingers on Mar 18, 2008 14:18:05 GMT -5
Howdy Folks, I've just finished my second tumble! It has taken a couple of months or so, as I have learned here, ya gotta get the patience thing down to be pleased with your results. I still have a long way to go with much to learn, but am enjoying the journey very much! (Again, RTH has been a real wealth of info for me, thanks to the sharing of many member's vast experience and creativity) I roll 12 lb. barrels, so have quite a few. I enjoy seeing nice close shots of stones, so as to avoid too many photos at one post, I will post some favs in separate threads. (I'm still on dial-up Ok, 'nuff said here they are. First up is Pet/Agatized wood from Montana. Thanks for lookin' Bill Group shot Will have 2 more posts worth of pet wood... hope ya wont get too bored with it.
one80mike
@(-_-)@ Princess Leia!
Member since February 2007
Post by one80mike on Mar 19, 2008 3:03:13 GMT -5
I love that group shot. They are super smooth and super shiney. Did you vibe or rotary tumble them?
Mike
Post by Titania on Mar 19, 2008 6:35:48 GMT -5
Those came out GREAT! You've got amazing colours and textures all represented there. Nice job!!
grayfingers
Post by grayfingers on Mar 19, 2008 6:56:07 GMT -5
Mike, I use a home built tumbler that runs 2, 12 lb, Lortone barrels. In the final stages I use lots of filler and run the barrels as full as I can and still get good movement of the stones, and that seems to keep the stuff that might fracture more cushioned. (like some woods, and thin agates) I polished with Cerium Oxide this batch, I think I got even better results than with the AO I tried last time. Bill
Post by krazydiamond on Mar 19, 2008 8:04:43 GMT -5
now that is a premier batch of pet wood, it don't get much better than that!!!!
KD
Post by stefan on Mar 19, 2008 8:25:08 GMT -5
I love WOOD!! Nice job on those! For Pet Wood I get better result with the AO- I also like using Tin Oxide on Pet wood- But my supply of Tin is running low- and it is not the cheapest stuff in the world- I've never had great luck with Cerium- Me thinks I might have to give it another go- Your stuff turned out great in it!
grayfingers
Post by grayfingers on Mar 19, 2008 17:37:40 GMT -5
Stefan, About the Cerium; I had a jar from Lortone, and also picked up a lb. from the Rock Shed. I noticed that Shawn's stuff was lighter in color (higher grade) than the Lortone stuff so I ended up mixing the 2 together. I would just get some from Shawn, unless the mixture had something to do with the shine, but I can't think of a logical reason it would have.
adrian65
Post by adrian65 on Mar 19, 2008 23:59:10 GMT -5
The last two woods (the white and the red) are extraordinary. You smooth the surfaces just perfectly. How long did you keep those ones in the first stage?
Adrian
SteveHolmes
Member since July 2009
Post by SteveHolmes on Mar 20, 2008 6:27:34 GMT -5
Beautuiful Batch of Pet Wood Bill! You should be HAPPY HAPPY JOY JOY with those results. Love the 2nd one. Steve
grayfingers
Post by grayfingers on Mar 20, 2008 6:27:34 GMT -5
Adrian, I run coarse (46/70) for as it takes, I like the natural shapes so I clean up any that have fractures or ragged breaks with the WF saw, which can reduce the time needed in coarse by a few weeks, most of these were ready to go to fine after 3-4 weeks.
Post by Bikerrandy on Mar 20, 2008 19:18:10 GMT -5
That's probably the best batch of petwood that I've seen, nice job!!
