montagieu
Member since March 2008
Post by montagieu on Mar 27, 2008 8:59:21 GMT -5
Good morning all, Here are some before and after pics of some ??breccia??. They have been in the 60-90 grit for 6 days. There was a lot of whole grit left at the bottom, proving that this is a fairly soft rock. It appears to have tumbled nicely with just a few vugs. I don't know how it will take to the final polish stage, but I like the looks of it so far. Very good patterning. If anyone has a better idea of what this type of rock is, please let me know. Before the tumble...... A well patterned piece of rough. A bucket o' rocks after 6 days in the 60-90 grit. Here I picked out a few of my favorites. Hope the pics turn out all right for everyone viewing. I took the last two pics in my garage using a flash from my camera. I like to use natural lighting, but that's not always available! -Montagieu
DeanW
Member since December 2007
Post by DeanW on Mar 27, 2008 10:12:00 GMT -5
I'd tend to call those you have a 'picture jasper' or rhyolite. Brecciated jasper, like Stone Canyon or Parkfield material in California is pretty different from that. Typical brec. material consists of more odd-shaped pieces re-cemented back together (ok, that's a lame way to describe it but that is all my brain can come up with right now).
Post by bobby1 on Mar 27, 2008 10:57:16 GMT -5
Usually that material is soft and grainy. When you squirt a dry piece does the water bead up on the surface or soak in? If it soaks in, chances are it won't polish very well. Bob
montagieu
Post by montagieu on Mar 27, 2008 11:42:48 GMT -5
When squirted with water, the rough soaked it up pretty fast. Still soaked up water pretty quick after the 60-90 tumble. I just put it in the 12-220 grit last night and will check again in a few days, if it hasn't fallen apart by then.
-Montagieu
Post by deb193redux on Mar 27, 2008 15:38:40 GMT -5
You may still get a high-satin shine. Very glassy shine is unlikely if the water does not bead up. Still, a fine wel patterened batch!
Post by Sabre52 on Mar 27, 2008 19:36:48 GMT -5
OK, I've seen that material in Texas and eastern New Mexico and it was called caliche though not true caliche which is sort of a white carbonate crust found on desert stones. I believe it's a layered formation of limestone that, in some cases, is somewhat silicified so it resembles wonderstone or picture jasper but is generally softer....Mel
montagieu
Post by montagieu on Mar 27, 2008 20:02:51 GMT -5
OK... it is time for me to reveal my sources.
I travel a lot to the Oklahoma Panhandle for my job. The road I take to my work site runs parallel to a railroad track. One day I pulled over to "inspect the tires" at a RR crossing and found that rock being used as ballast underneath a RR crossing sign. I grabbed a handful because of the patterning and took it home with me. There.... now everyone knows my secret.
I think I will continue the tumble and just see how it turns out.
Thanks you all for the input so far.
-Montagieu
Post by Titania on Mar 28, 2008 7:27:29 GMT -5
Those look pretty good, so far! I think it'll be an interesting experiment, even if they won't polish to a high sheen. You've really got nothing to lose.
