habbie
Member since February 2011
cuts
Jul 28, 2011 11:43:16 GMT -5
Post by habbie on Jul 28, 2011 11:43:16 GMT -5
I have a covington 10" saw. The problem I have is when I cut off a slab the last little bit of the slab breaks off!! I tried starting the cut then after a bit 1/4" or so stop the cut and back it out and start again. Nothing works !! is it me the saw or all of the above?
cuts
Jul 28, 2011 12:07:59 GMT -5
Post by jakesrocks on Jul 28, 2011 12:07:59 GMT -5
It's not you or the saw. I've never seen a lapidary saw that doesn't leave a little "break out nub". You can minimize this by releasing your power feed when you're about 3/8" from the end of the cut, and feed the last little bit by hand. Press the stone forward slowly, using just a little pressure. You'll still get a little nub at the end of the cut, but it will be less. Don
cuts
Jul 28, 2011 16:14:42 GMT -5
Post by Sabre52 on Jul 28, 2011 16:14:42 GMT -5
Yeah, Remember rocks aren't wood and do not have the same properties. Your blade is being pushed against the the workpiece with some pressure so as the blade nears the end of the cut, the pressure against the rock fractures it and it simply breaks off. This is true even if you hand cut the rocks without the power feed as rock is not fibrous in the same way wood is and so is much more brittle. You can use glass nipping pliers to break off the stub or grind it off but you ain't gonna stop it from happening.....Mel
amyk
I'm a slabber, I'm a cabber, I'm a midnight wrapper.
Member since January 2010
cuts
Jul 28, 2011 16:33:03 GMT -5
Post by amyk on Jul 28, 2011 16:33:03 GMT -5
It happens to every slab I cut.
habbie
cuts
Jul 28, 2011 18:44:59 GMT -5
Post by habbie on Jul 28, 2011 18:44:59 GMT -5
thanks so much for the input was thinking I had a hex against me LOL
So I guess you just leave enough material to plan for this
habbie
cuts
Jul 28, 2011 18:46:27 GMT -5
Post by habbie on Jul 28, 2011 18:46:27 GMT -5
Would it help if I taped the ends before I cut them?
cuts
Jul 28, 2011 19:09:04 GMT -5
Post by jakesrocks on Jul 28, 2011 19:09:04 GMT -5
Taping won't prevent the break outs. Cutting oil will probably soften the adhesive on the tape, and it will fall off before you complete your cut. The nub at the end of a cut is something we all just learn to live with.
cuts
Jul 28, 2011 22:36:16 GMT -5
Post by gr on Jul 28, 2011 22:36:16 GMT -5
Keep an old pair of side cutters by the saw and just nip it, nip it! and load the next one! I always cut them off as it is easier to stack them in the storage containers. I'm probably a little OCD about it but, that's just me.
gr
