darstcreek77
Member since April 2011
Post by darstcreek77 on Aug 27, 2011 6:27:37 GMT -5
how much gravity weight should be used on a saw when cutting agate flint ect ? 10 inch barranca 303 blade water cooled ?
Post by jakesrocks on Aug 27, 2011 8:16:42 GMT -5
This is a matter of experimenting. See how much weight it takes your vice to move empty, and start out by doubling that weight for cutting. You may have to add or subtract a little weight. For an old Star Diamond saw I had, I used a 3 pound fishing weight for soft material, and a 1-1/2 pound for harder material.
Post by johnjsgems on Aug 27, 2011 10:00:13 GMT -5
I guess the scientific way would be to use a fish scale and see how much weight it takes. If you feed by hand you can hear the motor sound change when feeding too fast. You can play with the weight to cut by sound.
