Post by gr on Oct 12, 2011 13:19:15 GMT -5
Good morning All! I was going thru some of the slabs that are buried in 5gal buckets in the shop and, ran across this piece. I was just wondering if, in the combined wealth of knowledge in this forum, if maybe someone might have an idea of what it is. It's around mohs 7 and not transparent at all. Was a rock that cooled very fast as the crystals are in the cryptocrystalline range. thanks for lookin....gr
Post by johnjsgems on Oct 12, 2011 14:47:54 GMT -5
Colors are right for Charoite.
Post by gr on Oct 12, 2011 16:37:15 GMT -5
John, if that be the case then this might be an expensive item?
Post by tandl on Oct 12, 2011 19:57:32 GMT -5
That is some cool colors together . you thinking metamorphic ? has it a white crust ? you sure about the hardness?
Post by gr on Oct 12, 2011 20:15:32 GMT -5
Ted, No igneous because of the rapid cooling structure (cryptocrystalline) and If I remember right, a file is 7 on the mohs scale and it barley scratches it. Yes ,it has a white crust all the way around it. kind of a hard crust at that. What are ya thinkin?
Post by tandl on Oct 12, 2011 20:19:49 GMT -5
the purple , i dont know what to think , but the green may be peridot.
Minnesota Daniel
A COUPLE LAKERS
Member since August 2011
Post by Minnesota Daniel on Oct 12, 2011 22:16:02 GMT -5
Post by gr on Oct 12, 2011 22:26:36 GMT -5
Daniel, thanks for posting that link! That looks alot like it and the one after it also
gary
Post by paulshiroma on Oct 12, 2011 23:13:03 GMT -5
Post by Sabre52 on Oct 13, 2011 0:08:08 GMT -5
The greenish part kind of throws me. Otherwise, I'd guess dumortierite in quartz, though I'm used to seeing it a bit more denim blue....Mel
Post by mohs on Oct 13, 2011 0:13:47 GMT -5
right on Mel I was thinking dumor too I have some of that denim blue dumor with the greenish & white in it Gary you should have a sample of that dumor
Post by tandl on Oct 13, 2011 8:26:34 GMT -5
Did you hound this Gary ? Dumo `s streak is white . Dumo can be green,blue ,violet,pink,brown, And can be more than one color in the same rock . deposits have been found near Yuma , AZ, , Near Oreana , Nevada . So north and south of ya .
JUDY
Member since September 2011
Post by JUDY on Oct 13, 2011 9:12:36 GMT -5
whatever it is... it's purty!!
Post by Donnie's Rocky Treasures on Oct 13, 2011 9:53:54 GMT -5
I agree with Judy, it is pretty!
rocpup
Pink Limb Iris
Member since March 2011
Post by rocpup on Oct 16, 2011 17:09:48 GMT -5
I have a whole lot of Dumo from the SE CA and Yuma area and none of it is green. Hard to see from the picture but my guess Wyoming Jade. Don
Post by frane on Oct 17, 2011 15:30:21 GMT -5
