Roger
Post by Roger on May 2, 2012 13:14:44 GMT -5
These are just too cool.. I'll grind them soon. Roger
unclestu
WINNER OF THE FIRST RTH KILLER CAB CONTEST UNCLESTU'S AGUA NUEVA AGATE
Member since April 2011
Post by unclestu on May 2, 2012 13:39:23 GMT -5
I would pay a good price if you were interested in selling me some. Would definately make it worth the diggin. They are breath taking. Stu
rocpup
Pink Limb Iris
Member since March 2011
Post by rocpup on May 2, 2012 14:02:26 GMT -5
Roger Tell us more What is theprocess
Roger
Post by Roger on May 2, 2012 17:15:50 GMT -5
These were very fractured so I sealed them in resin I use Super Clear Resin it very clear and easy to mix. A simple 2 to 1 ratio, I use a small scale for to be exact. I used to use Opticon but it yellows after it dries.I will grind them into cabs..
Roger
Post by Pat on May 2, 2012 17:37:14 GMT -5
They are beautiful. I hope your trick works. Have you sealed then cabbed before?
Roger
Post by Roger on May 2, 2012 18:42:43 GMT -5
I seal fractures all the time.
Roger
Post by talkingstones on May 2, 2012 18:45:47 GMT -5
Really? Is that the brand name for the resin? I would love to see these when you are done with them!!!
Cathy
TByrd
Have you performed your random act of kindness?
Member since December 2010
Post by TByrd on May 2, 2012 22:44:20 GMT -5
How long do you leave them in the resin? How long does it take to dry them after you take them out?
Tammy
Post by helens on May 2, 2012 22:52:35 GMT -5
Those are beautiful Roger:)!
Roger
Post by Roger on May 3, 2012 9:08:47 GMT -5
Hi,Ok here's how I use Super Clear Resin That is the brand name I found the ad in Lapidary Journal.I ordered it on line at Resin Obsession.I heat my rocks to about 150-200 degrees I mix the resin and try to warm it to the same temp as the rocks.I then brush or pour it on then I turn the oven off and put the cabs back in to cool slowly as the oven cools and its dust free in the oven.Then I grind them into cabs.
Roger
Post by roy on May 3, 2012 9:24:28 GMT -5
that 's cool do'es it stink up the house?
Roger
Post by Roger on May 4, 2012 9:14:38 GMT -5
No,That's another reason I switched to the Resin Obsession stuff.
Roger
hubrocks
Post by hubrocks on May 5, 2012 18:29:03 GMT -5
Those are super cool,and so is your sealing process.thanks Hub
Post by phil on May 6, 2012 13:53:20 GMT -5
Hi Roger. Are these agates for sale anywhere? Also the superclear... can a stone that is very pitted be dipped and set aside to dry or does it have to be brushed on? Thanks! Nice stones, can't wait to see the finished ones... Phil
