blackout5783
Post by blackout5783 on Jan 6, 2013 11:37:44 GMT -5
Last night I tried cutting some rainbow ob without much luck. I know you're supposed to cut parallel to the banding to get the rainbow effect, but is their such a thing as being too parallel? I mean if you cut dead parallel to the banding, will you get less of the rainbow effect than if you were slightly off?
Post by roy on Jan 6, 2013 13:50:02 GMT -5
for me it depends were the ob comes from some of the oregon stuff is really hard to capture the color,i have some from mexico that you cant go wrong! if yo find the color band and draw a line across the piece to cut i have some blue banded ob that i had to cut @7 degrees to get any color it's really trial and eror for me ! mabe someone ealse can help more
Simon
Post by Simon on Jan 7, 2013 12:57:46 GMT -5
Post by stoner on Jan 7, 2013 23:46:45 GMT -5
I've always had the best luck cutting rainbow obsidian about 15 degrees off the flow lines.
Post by bobby1 on Jan 8, 2013 2:12:33 GMT -5
I cut it perfectly parallel to the color bands and thicker than usual slabs are cut so you get a darker background. You will only get one color unless the bands are closely formed, then a high dome will show an eye with the other colors lying under the primary color. If it is a bright color it will show well this way regardless of the orientation. If you cut it at an angle to the color bands you do get to see all the colors but it only shows in one angle of orientation. If you rotate it slightly the color disappears. Bob
blackout5783
Post by blackout5783 on Jan 8, 2013 7:38:38 GMT -5
I cut it perfectly parallel to the color bands and thicker than usual slabs are cut so you get a darker background. You will only get one color unless the bands are closely formed, then a high dome will show an eye with the other colors lying under the primary color. If it is a bright color it will show well this way regardless of the orientation. If you cut it at an angle to the color bands you do get to see all the colors but it only shows in one angle of orientation. If you rotate it slightly the color disappears. Bob I think this is my problem. I cut it 1/4 in thick and it's just about transparent. Plus the color on this cut is purple so unless there's a dark color behind it, you'd never know it was anything other than black.
