RockIt2Me
Member since December 2009
Post by RockIt2Me on Mar 4, 2013 9:00:24 GMT -5
I am always amazed when people say they recover 60-80% of their oil. If I get 40% after filtering, I feel lucky. I think I have figured out why my recovery rate is so low. Maybe this is why I refer to her as "Puddin".
Post by Deleted on Mar 4, 2013 9:19:08 GMT -5
I am with you sister. I run my saw until the only thing in there is muck. The movement of the blade through the oil causes an area under the blade to be only oil (dirty oil) and all the heavy particles settle elsewhere. I never have to sharpen the blade. (ok, a couple of times), the blade just keeps cutting and cutting forever and it cuts so smooth that Helen thought I had polished the slabs I sent to her. In my opinion a clean saw is like a clean car. Just for looks. I am not preaching everyone. lol This is just my life experience. I have a feeling that you started a great thread and I would like to hear what everyone else has to say. Jim
Post by Deleted on Mar 4, 2013 9:20:30 GMT -5
BTW what have you been cutting? I never have that pretty reddish color.
milto
Member since January 2010
Post by milto on Mar 4, 2013 9:30:28 GMT -5
I have never seen a saw with that much oil in it!! Don't you have a lot of splash.Normally you have enough coolant to cover the diamond of the blade 1/4 to 3/8 of an inch.Wow.
milto
Post by jamesp on Mar 4, 2013 9:33:00 GMT -5
I know that you need to have the area around the blade clean.Tf the blade is picking up mud it makes uglier cuts.I slant my saw so that the mud slides down hill away from the blade pickup.I wish my saw had a sump w/a lift pan that i could rake the muck into.
RockIt2Me
Post by RockIt2Me on Mar 4, 2013 10:04:36 GMT -5
BTW what have you been cutting? I never have that pretty reddish color. That's Sonoran Dendritic Rhyolite Looks like I dressed a deer in there.
RockIt2Me
Post by RockIt2Me on Mar 4, 2013 10:06:17 GMT -5
I have never seen a saw with that much oil in it!! Don't you have a lot of splash.Normally you have enough coolant to cover the diamond of the blade 1/4 to 3/8 of an inch.Wow. milto That's not my oil....it's the muck covered deck my cuts fall on (don't know the technical term)
Post by Deleted on Mar 4, 2013 10:11:25 GMT -5
James, did you read my post? My filthy saw cuts so smooth that Helen thought I polished the slabs. It does not cut any different clean or dirty. (really dirty)
Really nice rock Nancie Jim
Post by jakesrocks on Mar 4, 2013 10:13:31 GMT -5
Hmmmm ! Been 3 years now. Think maybe I should shovel the mud out of my saw this spring ?
keystonecops
Member since October 2010
Post by keystonecops on Mar 4, 2013 10:28:25 GMT -5
Gonna try sumpn new for cleanin saw. Guy said he gets course nylon bags from a brewery supply, runs the oil through that to get rid of heavy stuff, then strains it through a paper bag. Later Clyde
blackout5783
Post by blackout5783 on Mar 4, 2013 10:40:32 GMT -5
Looks like I dressed a deer in there. It does sorta look like you were using it to dismember bodies...
QuailRiver
Post by QuailRiver on Mar 4, 2013 14:50:19 GMT -5
AAUUURRRGGG! THE INHUMANITY!!!!!!!
Post by Drummond Island Rocks on Mar 4, 2013 19:13:16 GMT -5
well mine's pretty darn dirty but it might look even worse since its 20 degrees here and the oil gets thicker the colder it is. I do love this saw but the full table top don't allow it to drain the oil back into the tank well at all. this is mineral oil after maybe 40 cuts these pics are actually after I had scraped up some of the goop so its usually even worse. Chuck
Post by beefjello on Mar 4, 2013 19:23:50 GMT -5
What the muck???
Heh.. sludge happens. I clean mine out once a year, and reclaim a decent amount thru filtering. One of these I'm a gonna try the shop vac sludge sucker thing I've seen on here.
Post by Bikerrandy on Mar 4, 2013 19:32:05 GMT -5
Rock pudding.... yep. Mine looks like that too. I'd change it more often if it wasn't so expensive. It's about time for me to filter it again, I really dread the process though.
Post by jamesp on Mar 4, 2013 20:02:43 GMT -5
My saw loads up if i let it gets that dirty(Covington 18 inch).I recently switched to kerosene and it is cheap and cuts very well.Just stinks bad.
RockIt2Me
Post by RockIt2Me on Mar 4, 2013 20:07:54 GMT -5
Now I don't feel so neglectful...
Post by rockpickerforever on Mar 4, 2013 20:18:57 GMT -5
When the sludge gets to the point where it is no longer a liquid, but instead you could spread it with a knife - that's when the saw ABSOLUTELY needs to be cleaned and the oil changed - LOL! I had a little bit of new mineral oil for the next cleanup, but needed to get some more. While I was at Walmart the other day, I picked up a half gallon - 4 pints @ $1.48 each. At that price, a gallon would be less than $12, and no shipping! I was ready to explain to the cashier why I was buying a half gallon of "Lubricant Laxitive" but she didn't ask. Jean
Minnesota Daniel
A COUPLE LAKERS
Member since August 2011
Post by Minnesota Daniel on Mar 4, 2013 20:33:18 GMT -5
Surely there must be a commercial use of rock puddin'?
Post by rockpickerforever on Mar 4, 2013 20:37:38 GMT -5
AKA rock snot! Maybe you could trowel various colors of it (reds/yellows/blacks) onto poster board and create art? Jean
