Post by kap on Jul 16, 2014 20:45:40 GMT -5
Looks like Adventurine?
Post by Sabre52 on Jul 16, 2014 20:45:42 GMT -5
Has nephrite/jadeite color but the jadeite I've worked seems even harder than nephrite. Definitely doesn't work like a soft stone. Serpentine often looks like jade and somewhat softer....Mel
Post by Deleted on Jul 16, 2014 22:37:29 GMT -5
My guess is aventurine too. Jim
Post by kk on Jul 17, 2014 1:57:48 GMT -5
Whatever it is, wonderful. Material to look at. Just a shame about the crack.
deserthound
Member since December 2013
Post by deserthound on Jul 17, 2014 23:41:33 GMT -5
Chrysoprase maybe
gemfeller
Member since June 2011
Post by gemfeller on Jul 18, 2014 1:47:10 GMT -5
I'm with Mel: serpentine.
Post by Deleted on Jul 18, 2014 10:03:52 GMT -5
deserthounddoes a pocket knife scratch this material? If you break a small piece of it what does the break look like? I am going to say negative on chrysoprase, wrong color. Also, negative on jadeite. You described it as "soft" and jadeite will never be described in this manner.
deserthound
Post by deserthound on Jul 18, 2014 13:29:49 GMT -5
deserthounddoes a pocket knife scratch this material? If you break a small piece of it what does the break look like? I am going to say negative on chrysoprase, wrong color. Also, negative on jadeite. You described it as "soft" and jadeite will never be described in this manner. a pocket knife will not scratch it, i said soft but i was comparing to the agate i have been cutting lately, id say hard as marble... a break is not clean and smooth like , its more rough, but not jagged wrong color or wrong shade pics off the web .....now the color i have to say is very close to what i have ...so i'm confusing here ?
Post by Deleted on Jul 18, 2014 14:26:00 GMT -5
Marble is easily scratched my a knife.
I see very different colors between the 'prase images you posted and your sample. You are seeing your stone in person. Perhaps the image isn't doing the sample justice.
'prase will have a glassy conchoidal fracture, as will aventurine.
You may have a jade family stone there. Too hard to be serpentine, but the series of stones between jade(s) and serpentine(s) is continuous. That meaning there are dozens [if not hundreds] of stones it could be. Without gemological analysis it may be impossible to say.
Post by Deleted on Jul 18, 2014 14:27:35 GMT -5
Oh yeah, the fact you were able to break it indicates it's not jade. If it were jade, you would have had tremendous difficulty breaking it and most certainly you would have been so impressed you would have mentioned it in your description of the break.
deserthound
Post by deserthound on Jul 18, 2014 14:50:46 GMT -5
thanks for all the info S/G..i have some known jade and it was different for sure..if you care to pm your address i will send you a piece of the unknown, not the jade..lol..i have some end cuts, no use to me, your welcome to it..
Post by Deleted on Jul 18, 2014 15:13:20 GMT -5
Oh Yeah!! I forgot SG!! What was your SG on this piece? Under 2.9?
knifegirl
Member since July 2014
Post by knifegirl on Jul 28, 2014 10:19:59 GMT -5
It can be hard to identify some materials. Jade is tough stuff like some have mentioned. Color is great. All kinds of tests that you can go right down to wrapping a hair around it and seeing if it will burn. They say that it has something to do with the coolness of the stone and that Jade stays cool. I have found this all frustrating because I don't want to say something is Jade if it is not. Hope you work something up and post it.
Post by snowmom on Jul 28, 2014 12:27:23 GMT -5
sounds too soft, what about soapstone? We have that here, and its usually light green...very smooth grained stuff but quite soft.
