Post by stardiamond on Jun 27, 2015 16:06:30 GMT -5
These got glued today and I will start cutting them on Tuesday. I have 6 more boards that I glued yesterday and will cut tomorrow.
Post by snowmom on Jun 27, 2015 16:20:58 GMT -5
this is gonna be good. Watching with interest- bring it on!
Post by woodman on Jun 27, 2015 18:43:05 GMT -5
How do you align the blocks in the vise so that you get good slabs right down to the wood? I glue pieces that have a cut on them to one that was just cut and still in the vise. I use a piece of cardboard and superglue, never had one come loose. Just wondering.
Post by stardiamond on Jun 27, 2015 18:50:39 GMT -5
I'm still new to this. I have the block extending out past the vise and will try to make the last cut about slab thickness from the wood. I'm using Sodium Silicate as an adhesive for the first time. It is suppose to dissolve relatively quickly in water. I used wood glue before and couldn't get it off by soaking for a long time. I ended up popping off the glued slice with a chisel. My biggest concern is not having anything come loose from the board when I'm making my cuts.
Post by Rockoonz on Jun 28, 2015 0:41:23 GMT -5
I glue to the end of the 2x4 instead of the side and leave it long enough that it will be square in the vice. Most vices are very close to 90 degrees and the last slab will be very close to parallel.
Post by Fossilman on Jun 28, 2015 18:22:18 GMT -5
No problems with that way,on glueing rocks to wood,can slab it right to the wood..............It's the only way I will do it too............ Looks great!!!!!!!!!!
