Roger
Post by Roger on Sept 14, 2015 19:45:07 GMT -5
Post by rockjunquie on Sept 14, 2015 21:28:00 GMT -5
Wow, Roger- that arrowhead came out great. I bet that was fun to mess with. The druzy oj is fabulous!! The video looks very good, I don't know what you were complaining about. I'm not sure what a "Richardson Ranch dry buffer" is, but it sure seems to polish well!
bsky4463
Member since September 2013
Post by bsky4463 on Sept 14, 2015 21:47:38 GMT -5
The arrowhead turned out great...looks like you still have your finger tips so the Richardson sander experience must have gone well The slab Looks killer. Cheers
rockroller
Be excellent to each other.
Member since October 2013
Post by rockroller on Sept 15, 2015 22:38:12 GMT -5
Yep, these all look great! The video does do a lot to show off that cab. Very nicely done!
~Roland
Roger
Post by Roger on Sept 16, 2015 6:43:15 GMT -5
The arrowhead turned out great...looks like you still have your finger tips so the Richardson sander experience must have gone well The slab Looks killer. Cheers The sander is a little nerve-wracking lol. 3400rpm is moving fast, but the results are amazing. I am debating trying to build one...
Post by Drummond Island Rocks on Sept 16, 2015 7:04:04 GMT -5
The arrowhead is impressive. That material was a great choice for it too. Should be easy to wrap with the notches cut in like that.
bsky4463
Post by bsky4463 on Sept 16, 2015 7:38:30 GMT -5
The arrowhead turned out great...looks like you still have your finger tips so the Richardson sander experience must have gone well The slab Looks killer. Cheers The sander is a little nerve-wracking lol. 3400rpm is moving fast, but the results are amazing. I am debating trying to build one... I have seen them for about $150, it would be pretty hard to build one for that price....if your not in a hurry you might find one on CL. But then again building your own has a fun factor...wouldn't be hard. As been said often before the key is to keep the rocks you are sanding from over-heating, rotating thru a line up. You did that Turk agate proud, looks great. Cheers
Post by paulshiroma on Sept 16, 2015 8:06:52 GMT -5
Impressive!
Post by Noosh9057 on Sept 16, 2015 9:09:04 GMT -5
Looks great.
