braat
Member since December 2016
Post by braat on Feb 8, 2017 10:56:03 GMT -5
Mine broke after 3 1/2 months of 24/7 running. Bought 2 replacements at a local farm supply store and they feel kinda "plasticy" compared to the original rubber one and are slightly smaller (just) in thickness/diameter. I adjusted belt tension down from where I had it and put in a new one and it broke after a few hours...replaced with remaining new one and it's still going 3 days later so we'll see how long this one lasts. All of which got me to wondering how long your belts last?? I have the Lortone 3A tumbler. Tks...
Wooferhound
Lortone QT66 and 3A
Post by Wooferhound on Feb 8, 2017 12:05:51 GMT -5
I have a 3A that's been running since Christmas day on the original belt. One day I put the drum on and missed the groove on the drum and it locked up the barrel for a day before I found it. It took a bit of twisting by hand to get the roller restarted but it's been running fine since then. My tumbler came with a spare belt which I still have.
Post by greig on Feb 8, 2017 14:32:21 GMT -5
I was doing fine with the original belt, until I started to overload with heavy tumbles (silver ore). I replaced it once with an aftermarket belt and the same thing - regular rocks were fine, but when I stupidly overloaded/overweight, it did not last 12 hours.
ChicagoDave
Member since June 2016
Post by ChicagoDave on Feb 8, 2017 14:35:45 GMT -5
I have been running 2 QT66s for about 7 months 24/7 with no belt issues.
Post by Drummond Island Rocks on Feb 8, 2017 15:12:33 GMT -5
I have been running 2 QT66s for about 7 months 24/7 with no belt issues. The QT series does not use an O-ring like the smaller tumblers. The QT series uses a flat belt with cogs. I have been using and abusing a couple QT'S for years without one breakage. Those are tough belts. QT belt Chuck
ChicagoDave
Post by ChicagoDave on Feb 8, 2017 15:28:06 GMT -5
Ah, I did not know there was a difference. Good to know!
Post by Fossilman on Feb 8, 2017 16:25:27 GMT -5
Mine last a couple of years and I load mine heavy...
salpal48
Member since March 2015
Post by salpal48 on Feb 8, 2017 18:39:18 GMT -5
You can Use a Variety ob belts For the Lortone 12 Lb. Or 6. The original Is a Cogged . and Durable Roc shed Uses Opti belt also cogged. There excellent belt but They make Noise and Chatter . It does not affect anything but annoying. You can get O- ring from The o-ring store. . The One I have been using Last a few Tears. . They make dufferent Grade. i use The 70 BUNA. 3/16 Diameter The # I use. /// 349 EPDM 70 BUNA . there cheap and you can Buy a Dozon. The Thumler takes a 343 EPDN 70 BUNA
