Post by sophia13 on May 27, 2018 8:43:19 GMT -5
Newbee question here...What is the name of the small metal pin that fits in the autofeed shaft near the allen/hex screw. I took it out and now it's in two tiny slivers and won't go back in. Thank you.
Post by woodman on May 27, 2018 8:57:50 GMT -5
Chances are it is cold rolled pin, Ace hardware will have them.
Post by johnjsgems on May 29, 2018 18:24:34 GMT -5
We always called them "roll pins". Hardware or auto parts. Or my neighbor's garage but that may not be as convenient for you.
Post by quartz on May 29, 2018 23:58:42 GMT -5
10 or so years ago some wise .ss decided the things we have called "roll pins" for years now need to be called "spring pins". Might need to make this distinction if dealing with a counterman under 40 yrs. old. Had fits ordering them at work; young vender rep.
zarguy
Member since December 2005
Post by zarguy on May 30, 2018 8:47:00 GMT -5
I'm sort of in the same boat - I'm taking apart a Raytech 10" saw with powerfeed. What's the best way to remove those pins? Do you have to destroy them to remove them? They tend to spread out & lodge themselves in the hole when I try to push them out with a nailset or similar punch. Is there a dedicated tool? Lynn
Post by woodman on May 30, 2018 9:09:57 GMT -5
I'm sort of in the same boat - I'm taking apart a Raytech 10" saw with powerfeed. What's the best way to remove those pins? Do you have to destroy them to remove them? They tend to spread out & lodge themselves in the hole when I try to push them out with a nailset or similar punch. Is there a dedicated tool? Lynn Just use a punch the same size as the pin, too small and the punch will go inside the roll pin, spring pin or whatever it is called these days!,
Post by aDave on May 30, 2018 13:05:55 GMT -5
I'm sort of in the same boat - I'm taking apart a Raytech 10" saw with powerfeed. What's the best way to remove those pins? Do you have to destroy them to remove them? They tend to spread out & lodge themselves in the hole when I try to push them out with a nailset or similar punch. Is there a dedicated tool? Lynn You can try what woodman suggested, but there are actually roll pin punches. I got a set for working on particular rifles I have. That said, regular punches (not nail sets) can work as long as the punch tip won't go into the hole and is the same diameter as the pin. It will also, more than likely, have to be straight sided and not tapered. ETA: Here's an Amazon ad that shows a good view of what roll pin punch tips look like. www.amazon.com/MulWark-Assorted-Corrosion-Resistant-Automotive/dp/B01N1HXR7A/ref=sr_1_5?ie=UTF8&qid=1527703664&sr=8-5&keywords=roll+pin+punch+set
Post by grumpybill on May 31, 2018 18:15:48 GMT -5
We always called them "roll pins". Hardware or auto parts. Or my neighbor's garage but that may not be as convenient for you. Could be especially inconvenient if he's home and catches you...
zarguy
Post by zarguy on May 31, 2018 23:53:24 GMT -5
I'm sort of in the same boat - I'm taking apart a Raytech 10" saw with powerfeed. What's the best way to remove those pins? Do you have to destroy them to remove them? They tend to spread out & lodge themselves in the hole when I try to push them out with a nailset or similar punch. Is there a dedicated tool? Lynn You can try what woodman suggested, but there are actually roll pin punches. I got a set for working on particular rifles I have. That said, regular punches (not nail sets) can work as long as the punch tip won't go into the hole and is the same diameter as the pin. It will also, more than likely, have to be straight sided and not tapered. ETA: Here's an Amazon ad that shows a good view of what roll pin punch tips look like. www.amazon.com/MulWark-Assorted-Corrosion-Resistant-Automotive/dp/B01N1HXR7A/ref=sr_1_5?ie=UTF8&qid=1527703664&sr=8-5&keywords=roll+pin+punch+setThanks. I ordered a set yesterday. They'll be here tomorrow. Lynn
